Hello
Guest
it is
November 23, 2026, 02:43:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 reload Question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 reload Question (Read 8804 times)
gene8522
117
on:
December 22, 2013, 08:57:26 AM »
I am having a "crash" problem with Mach3 (see previous post) so I decided to try a reinstall of Mach3. I have everything working but when I load the G Code into Mack3 it will only run just a few lines of the code then stops and the rest of the toolpath window is blank and the 'Black' window is not showing all of the toolpaths. If I look at the 'notepad' editor it shows all of the Gcode. I'm sure I have missed setting something in the program but I can't find the problem. Where might I find the setting to correct this?
Gene
Logged
ger21
6,295
Re: Mach3 reload Question
Reply #1 on:
December 22, 2013, 10:24:44 AM »
You don't have your License file in the Mach3 folder.
Logged
gene8522
117
Reply #2 on:
December 22, 2013, 12:09:29 PM »
ger21
I can't thank you enough for the help. Mack3 is working. NOW if it will only NOT "crash" I will be happy. At least until the next problem comes up with my CNC.
Logged
Print
Pages:
1
Go Up
« previous
next »
