Mach Discussion => General Mach Discussion => Topic started by: gene8522 on December 22, 2013, 09:57:26 AM
I am having a "crash" problem with Mach3 (see previous post) so I decided to try a reinstall of Mach3. I have everything working but when I load the G Code into Mack3 it will only run just a few lines of the code then stops and the rest of the toolpath window is blank and the 'Black' window is not showing all of the toolpaths. If I look at the 'notepad' editor it shows all of the Gcode. I'm sure I have missed setting something in the program but I can't find the problem. Where might I find the setting to correct this? ??? ??? ???
Gene
You don't have your License file in the Mach3 folder.
ger21
I can't thank you enough for the help. Mack3 is working. NOW if it will only NOT "crash" I will be happy. At least until the next problem comes up with my CNC. :o ;)
