Hello Guest it is September 23, 2026, 05:10:52 PM
Author Topic: Tachus42 Drivers and motors works in Kcam 4 and Not working in Mach3  (Read 37747 times)
Re: Tachus42 Drivers and motors works in Kcam 4 and Not working in Mach3
« Reply #10 on: December 22, 2013, 04:34:57 PM »
can u check this file, i'll try it again tomorrow , check motor tuning , pins , output , input . ...
all measure in MM
« Reply #11 on: December 24, 2013, 06:25:57 AM »
i tried everything can change , no new
« Reply #12 on: December 24, 2013, 07:57:18 AM »
If you go to the Diagnostics screen do you see a frequency and a Time in Int?
« Reply #13 on: December 24, 2013, 02:40:44 PM »
Do u mean when i try with connecting electronics or with idle ??
this screenshot is when idle no driver or motors connected :
i'll added later screenshot when connect and give gcode...
« Reply #14 on: December 24, 2013, 05:12:28 PM »
That looks reasonable, one thing however that looks strange is the Port 1 Current state, I would have expected some to be green. Are you sure you have the correct port address selected?
« Reply #15 on: December 25, 2013, 03:39:17 PM »
yes , same pins doe dir and dist in the Kcam :(
« Reply #16 on: December 26, 2013, 04:32:34 AM »
Dont have an answer for you I am afraid, if everything is set correctly and the driver would seem to be loaded and working then it should work.
« Reply #17 on: December 26, 2013, 07:13:05 PM »
i found this topic, and downloaded the xml file attached their and in Diagonisitc Tab i got 5 pins Green .
i tried to figure the same pins and dir inside it, but the motor with no action ,
i tried to re-install Xp sp3 again , but no change ...
i use Dell Latitude E5400 laptop  and bought  " legacy Extender " to get parallel port  and it worked before good with Mach3 with previous board .
i will try later with PC and see what the problem ,
it make me angry it works well with kcam till now ...  :( so it's not port problem ...
« Reply #18 on: December 27, 2013, 05:18:42 AM »
Edit  : i tried the same xml file at another PC , worked before with previouse driver in the same pc with the same xml file , still nothing .. and the Diagnostic screen still without any green pins ....
« Reply #19 on: December 27, 2013, 08:51:55 AM »
The diagnostics screen may be a red herring, it is something I usually ignore as no one really knows what they correspond to, however I dont think I have ever seen them all out and that is why I mentioned it.
Can you test direct at the port with a volt meter or a scope to see if you are getting outputs when you jog one way or the other. You should get 0v to 5v when you jog back and forth.
