Hello Guest it is October 11, 2026, 10:06:49 AM
Author Topic: Having trouble setting up the UC100 CNC controller  (Read 29589 times)
« on: December 06, 2013, 04:57:01 PM »
Hello, Im having trouble setting up the UC100 CNC controler/adapter. I downloaded the automatic setup file and it moved itself to the Mach3 file. But it doesn't seem to do anything. Im running windows 7 32bit on bootcamp. Any help would be much appreciated!
Offline derek
  •  200 200
Re: Having trouble setting up the UC100 CNC controller
« Reply #1 on: December 06, 2013, 07:18:09 PM »
Did you do all the steps in the PDF?
http://cncdrive.com/MC/UC100%20datasheet/UC100%20users%20guide.pdf
When you plugged the UC-100 in did it load the drivers.
Did Mach ask you what controller you wanted to use when you started it?
Derek
« Reply #2 on: December 07, 2013, 03:51:24 AM »
Yes I've done the first steps but with the driver downloaded, UC100 plugged in and then open Mach3 it does nothing. The screen to choose the control device does not come up and there are no other changes to Mach3.
Offline derek
  •  200 200
« Reply #3 on: December 07, 2013, 04:54:36 AM »
Does it show up in the "configure plugins" menu under the config drop down?
Is it listed in the plugin control drop down?
In the Mach3 plugins folder is the UC100 DLL listed?
Derek
« Reply #4 on: December 07, 2013, 05:14:10 AM »
No it doesn't show up in the config plugins
Offline derek
  •  200 200
« Reply #5 on: December 07, 2013, 05:14:54 AM »
« Reply #6 on: December 07, 2013, 05:15:27 AM »
The DLL is listed in Mach3 folder too.
Offline derek
  •  200 200
« Reply #7 on: December 07, 2013, 05:20:07 AM »
Well the config plugins should show all the plugins in that folder. I would toss out the DLL and reinstall from a fresh download.
« Reply #8 on: December 07, 2013, 05:24:53 AM »
Okay I'll give it a go. I will let you know how i go. Thanks for your help so far!
Offline derek
  •  200 200
« Reply #9 on: December 07, 2013, 05:26:51 AM »
No problem.
You can download the DLL by itself here
http://www.cncdrive.com/downloads.html
