Hello Guest it is October 24, 2026, 12:02:21 PM
Author Topic: Having trouble setting up the UC100 CNC controller  (Read 29719 times)
Re: Having trouble setting up the UC100 CNC controller
« Reply #10 on: December 07, 2013, 05:35:57 AM »
Ok, so I deleted the old file, downloaded another (UCx00 automatic installer application) Put it in the Mach3 file, started Mach3 and still nothing..... I'm nearly tearing my hair out!! haha
« Reply #11 on: December 07, 2013, 05:47:34 AM »
I'm pretty sure I'm doing it right. Nothing comes up when i plug it in and open Mach3. When I download the file i just move it to the Mach3 folder don't I?
Offline derek
  •  200 200
« Reply #12 on: December 07, 2013, 06:06:46 AM »
Ok this my be the problem.
The .m3p is an installer. If you are dropping that in the plugins folder it won't work. Plop it on your dektop, double click and it will install the .DLL in the mach folder.
There are only two components. the windows USB driver and the Mach plugin. Download the plugin from the link I gave you and double click to install.
« Reply #13 on: December 07, 2013, 06:16:37 PM »
I just tried doing that and when I clicked on it on the desktop it came up with an error saying "corrupt install, no license found. Aborting." (I have paid for the license and it shows at the top of Mach3 that it's registered) after that error goes away, a heap of files appear on the desktop. Maybe I am supposed to transfer these files to Mach3?
Sent from my iPhone using Tapatalk
Offline derek
  •  200 200
« Reply #14 on: December 09, 2013, 05:07:56 AM »
The m3p installer should only be installing the DLL file to the plugins folder.
I don't have a windows 7 machine so I'm not sure where to tell you to go from here.
CNCDrive.com has a contact link on their site. Balazs is usually pretty quick to help.
Derek
« Reply #15 on: December 09, 2013, 05:23:26 AM »
If you grab the m3p and place it in your plugins folder you can then simply change the file extension of it to .dll and it should be seen on next start of Mach.
« Reply #16 on: December 09, 2013, 05:22:07 PM »
Is the M3P file "UCx00 automatic installer application" or do I have the wrong one? To change it to a .dll do I just click on it?
« Reply #17 on: December 09, 2013, 05:27:45 PM »
This is what it says when I click on the auto setup file
« Reply #18 on: December 09, 2013, 05:32:47 PM »
Then when I put the auto installer file into mach3 and click on it. Mach3 opens normally and there is no sign of it recognizing the UC100
« Reply #19 on: December 10, 2013, 02:00:56 AM »
Afraid I have no idea about the UC100 and its plugin/installer, if it is not a m3p file you are downloading then you will have to do as you are instructed by them.
