Hello Guest it is September 09, 2026, 09:25:19 PM
Author Topic: Table is not in level?..... cnc3040  (Read 20648 times)
« on: December 01, 2013, 06:26:03 AM »
I'm new with cnc and now i have a cnc3040.  The problem I have is that everything else is working fine but the Z axis is not....
When I'm cutting lets say a piece of wood 200mm x 150mm so on the right side it is much more deeper than on the left side...
Why is it so? I have used all the settings that came with the machine...
Thanx for your help, hope you understand me.
Thomas
Finland
Re: Table is not in level?..... cnc3040
« Reply #1 on: December 01, 2013, 06:33:35 AM »
And I use Vcarve 6.0
« Reply #2 on: December 01, 2013, 06:40:56 AM »
The table top, X Y  plane,  should be parallel to the movement of the gantry. You shold at east check to see the condition.
 If you have adjusting screws for the table top make it so. Even if you do, you still can improve by making a light cut across the complete table top.
« Reply #3 on: December 01, 2013, 06:57:03 AM »
Here you can see
http://youtu.be/57xY94SnlCQ
It is like when I'm moving the spindle so the deep is okay all the way, but when I'm using vcarve or gcode the spindle is going like the table aint in level...
Thomas
Offline kolias
  •  1,165 1,165
« Reply #4 on: December 01, 2013, 08:15:32 AM »
Post the gcode of the cut you did on the video
Nicolas
« Reply #5 on: December 01, 2013, 09:58:42 AM »
They are all same, made by vcarve pro 6.0
Doing something wrong with vcarve?
« Reply #6 on: December 01, 2013, 10:14:38 AM »
Here is the gcode:
( test )
( File created: sunnuntai, joulukuu 01, 2013 - 06:13 )
( for Mach2/3 from Vectric )
( Material Size)
( X= 200.000, Y= 150.000, Z= 10.000)
(Toolpaths used in this file:)
(Profile 1)
(Tools used in this file: )
(1 = Engrave {20' 0.02" Tip Dia})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (Engrave {20' 0.02" Tip Dia})
N140G00G43Z25.400H1
N150S8000M03
N160(Toolpath:- Profile 1)
N170()
N180G94
N190X0.000Y0.000F1200.0
N200G00X5.000Y5.000Z3.175
N210G1Z-0.200F480.0
N220G1X195.000F1200.0
N230G1Y145.000
N240G1X5.000
N250G1Y5.000
N260G00Z3.175
N270G00Z25.400
N280G00X0.000Y0.000
N290M09
N300M30
Offline kolias
  •  1,165 1,165
« Reply #7 on: December 01, 2013, 10:37:21 AM »
I'm not an expert with gcode but looks like line N200 of the gcode the Z is at 3.175 which to me is too high. To me this should have been 0.00
Then in line N210 the Z is -0.200 which means you do actual cutting (because it is a negative value)
I think the problem is how you set the depth of cut in Vectric
But someone else who knows the gcode will explain this better
Nicolas
« Reply #8 on: December 01, 2013, 10:40:45 AM »
Ok,
How about the feed rate and plunge rate? Can it have something to do with them? I don't know whats a good setting for vcarve 6....
« Reply #9 on: December 01, 2013, 11:18:58 AM »
This is the retract height, and is correct. It should NOT be 0.00
There's nothing wrong with the g-code.
The proper procedure is to mechanically adjust the table to be as flat as possible, then mount a sacrificial spoilboard to it, and surface that flat with the machine. Then, any work you attach to the table will be flat for your v carving.
