Hello Guest it is November 22, 2026, 06:10:46 PM
Author Topic: Best simple CAD/CAM software  (Read 34007 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Best simple CAD/CAM software
« Reply #10 on: November 17, 2013, 05:10:16 AM »
Jim, glad to know you are making progress with CamBam. Once you get the idea of the workflow, going from drawing to creating toolpaths to GCode it gets easier. When you click the exit Gcode button in Mach3 it will pull up what ever GCode you have loaded in Mach3 in Notepad. If you don't have the GCode loaded in Mach then it won't bring anything up. You could also load CamBqm on your shop PC as well, just don't try to use CamBam while Mach moving your machine. One other tip is to copy the files from you pen drive to your shop computer, don't run them off the then pen drive; strange things can happen if you do.
Happy machining , Jeff Birt
« Reply #11 on: November 17, 2013, 07:29:21 AM »
Jim, in Mach3. go to Config > General Config.
At the top of the page, under "Editor", make sure it says "\Windows\Notepad.exe". If it doesn't, use the Browse button to find the location of Notepad on your PC.
« Reply #12 on: November 17, 2013, 09:12:37 AM »
he means "EDIT Gcode" button.
« Reply #13 on: November 17, 2013, 05:34:09 PM »
Jim,
Install CamBam on the CNC machine too.  You really want to be able to jump back and forth into CamBam and Mach 3.  When you measure a part and it is a little off you are going to want to revise the toolpath or change the tool diameter to correct it.  You'll run a part and then realize there is a much better way to  organize the operations and you'll want to quickly jump into CamBam make the changes and repost.  I find myself doing this a LOT!
« Reply #14 on: November 18, 2013, 12:49:37 AM »
Thanks everyone for the advice, learning fast and thinking of getting the cut viewer as a collision checker. Gary your right it needs to be near the machine, but its cold down the shed (workshop) this time of the year. I found a couple of errors when practicing constructing parts in the living room which I corrected in CamBam. Hold on there's a space in the living room by the TV I could fit my machine. Just got to get the OK of the wife!!!!
Once again thanks for all the advice.
Jim
  •  9,378 9,378
« Reply #15 on: November 18, 2013, 01:02:16 AM »
 ;D ;D ;D
« Reply #16 on: November 18, 2013, 02:04:34 AM »
I think you may have the letters mixed up, Do you not  mean that when you suggest that you will get KO'd from the wife?
