Hello Guest it is November 13, 2026, 01:00:13 PM
Author Topic: Machanical Automatic Tool Changer  (Read 140133 times)
Re: Machanical Automatic Tool Changer
« Reply #70 on: February 06, 2014, 12:46:51 PM »
Cant recall where we were, do you have 3 phase power? If so is it just 230v 3 Phase?
Is the spindle drive you have dead?
 It does look like it is not a servo but rather just an AC spindle motor, it would still be a decent spindle motor if you have the drive for it.
Depending on your answer regards the 3 phase I may be able to point you to some motors and drives on Ebay that may do you. I have not looked recently but there are nearly always ones on USA Ebay.
« Reply #71 on: February 06, 2014, 12:57:35 PM »
You got it, 3 phase 230v.
The drives I have a monstrous (about 2'x1.5'x1'), filthy, and in unknown working condition, but I could do a car battery test on the motors and verify their working condition.  The encoder is also an issue because it is some wonky belt driven unit separate from the motor, and I am quite sure that they cannot be salvaged.
« Reply #72 on: February 06, 2014, 12:58:15 PM »
If I could keep the motors that would be ideal, but I assume that without the drive and functional encoder I could be SOL.
« Reply #73 on: February 06, 2014, 01:15:36 PM »
Thats  a shame that its just 230v 3 phase as it makes it harder to find a servo that will be similar specs to the  one you have.
You wont be able to test with a car battery as it is an AC motor.
Will have a search of USA Ebay and see if I can find anything that may be suitable for you but think the RPM will be the issue.
« Reply #74 on: February 06, 2014, 01:24:15 PM »
That was what I found when I called around, a motor capable of that wide of an RPM range gets pretty expensive.
The AC servo motors from china look physically identical unlike most of the induction motors I have seen, and have nearly the same specs as I found on my motor, but the information they sent me and the information on their website are conflicting, one says 220v 3 phase and the other shows 380v 3 phase...
« Reply #75 on: February 06, 2014, 01:29:51 PM »
I would say that is a dual winding AC spindle motor and not a servo. They are physically much bigger than a comparable servo.
Does your spindle fit via belt drive or is it direct, if belt then it may be possible to get a 3000rpm servo and gear 2:1
« Reply #76 on: February 06, 2014, 01:31:29 PM »
Just looking through the various pictures and I found a detail of the spindle driver "AC SPINDLE SERVO UNIT TYPE A06B-6044-H008" and the motor is "TYPE A06B-1003-B100"
I will look into those and see if it reveals anything else...
« Reply #77 on: February 06, 2014, 01:33:21 PM »
And of course to make everything super convenient, I have 2 different spindle controllers...
« Reply #78 on: February 06, 2014, 01:37:17 PM »
Scratch that, I have 3 different ones.  I see the A06B-6044-H008 on fleaBay, but I'm skeptical at best about buying a used 20+ year old driver for $1000+
« Reply #79 on: February 06, 2014, 01:51:16 PM »
Ok if it is an AC servo then it may be possible to use a different drive although you may need a different encoder as I think Fanuc use proprietary ones. You mentioned the encoder was via a belt but if its an AC servo then I think there will be an enoder on the motor itself and the one on the belt will just be for the control for spindle position.
