Hello Guest it is October 24, 2026, 11:18:27 PM
Author Topic: spindle going the wrong way  (Read 37706 times)
« on: September 23, 2013, 02:47:16 PM »
Hi me again i have sorted all the other problems out that i have had  and now what the problem is the spindle going the wrong way round !!!! i am using mack3 and xinfutai vfd‏ inverter i am controling the spindle by this. so when i turn the control knob it gos the wrong way please can someone help before i go mad thanks Tom
Re: spindle going the wrong way
« Reply #1 on: September 23, 2013, 02:59:30 PM »
Depends how you are actually controlling the VFD but if using a Dir pin then you could change the active state for it in Ports and Pins. If its modbus then I am not sure how it works as I have never set a spindle up via modbus however you should be able to set a parameter in your VFD to give you the opposite rotation.
« Reply #2 on: September 23, 2013, 04:37:44 PM »
If the spindle is rotating the wrong way, you need to swap any two of the three wires connected to the spindle motor.
This a a standard way to reverse the direction of a brushless three phase motor.
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
« Reply #3 on: September 23, 2013, 05:44:35 PM »
Hi hood thanks for the info but to be honest with you i dont know alot about  modbus i just control it with the control knob on the vdf unit i want to set it up so mack3 can control it but i not sure what to do that thanks
« Reply #4 on: September 24, 2013, 02:03:05 AM »
Doh, Peter is correct, I think servo all the time and forget about Induction motors even when I am talking VFD ::)
« Reply #5 on: September 24, 2013, 04:44:21 AM »
Hi Hood i thick that would be might be quicker for me to do that but there is 3 wires that come out of the unit so which ones do i swoop over cos knowing my luck i move the wrong cable and blow the lot up the way my luck going lol thanks Tom
« Reply #6 on: September 24, 2013, 12:46:07 PM »
It doesn't matter. Swap any two of the three motor wires going to the spindle excluding the ground, DO NOT SWAP THE GROUND!!!
« Reply #7 on: September 24, 2013, 01:27:35 PM »
hi thanks for your help peter/hood all working fine now thanks to you two  :)
« Reply #8 on: January 13, 2023, 11:44:16 AM »
I had a computer crash, i was able to save all my .xml and lic.
I loaded mach 3 on the new computer and have it running, but now when i start my progam M03 is going the wrong way. I did not touch anything with the motors or servos, only thing i changed was the computer itself.
Also i cannot feed hold and resume in a program like i could before.
