Hello Guest it is November 12, 2026, 02:21:54 AM
Author Topic: Meccanicca Cortini - Mach3 - C11 BOB - Gecko G213V  (Read 15772 times)
« on: September 22, 2013, 05:12:33 PM »
I've got this nice little mill that I converted to modern controller/driver/stepper setup.
After wiring it all up, everything moves the way it should.
Listen to the stepper motors as the program mills a circle tho, sounds like a car shifting 1,2,3 when acc/decc at the quadrants of the circle.
I can't get friendly with it... the transmission is toothed-belt. Can anybody hear something I should double check on ?
http://youtu.be/7EOwui47Moc
Thanks for any suggestions.
I'll post some more pictures of the setup when I get out of the shop  :)
 Marco
Re: Meccanicca Cortini - Mach3 - C11 BOB - Gecko G213V
« Reply #1 on: September 22, 2013, 06:56:40 PM »
Hi Marco; sounds like your stepper motor accel values are very conservative (slow).  Try increasing the accel values and see if that helps.:)
Milton from Tennessee ya'll.
« Reply #2 on: September 22, 2013, 11:27:42 PM »
Here is what happened so far...
Machine: Meccanica Cortini C3 with Cortini 2437 controller and Zebotronics driver and motors made back in 86.
I bought the machine 3 years ago and used it in it original setup.
Was a strong and consistant workhorse.
The memory board finally gave up rendering the machine useless for production.
I decided to go with Mach and Gecko with 950oz NEMA34 stepper motors.
