Hello Guest it is October 21, 2026, 11:43:03 AM
Author Topic: TB 6560 BOB LIMIT SWICH CONNECTIONS  (Read 18574 times)
« on: September 22, 2013, 02:15:38 PM »
Hi ALL
I am not an electronic engineer but how do you connect the limit switch wires to the male receptical 10 mm x 3 mm with
5 small pins sticking up inside on the above BOB
I presume you need a female pug to connect it but despite extensive search's for one I canot find one in GB
Graham
  •  9,374 9,374
Re: TB 6560 BOB LIMIT SWICH CONNECTIONS
« Reply #1 on: September 23, 2013, 07:44:56 AM »
Hi Graham,
Can you post a link to, or information on, the TB6560 board you have (there seems to be many different types).
« Reply #2 on: September 23, 2013, 02:26:19 PM »
Tweakie
This is the plug I am refering too
Graham
  •  9,374 9,374
« Reply #3 on: September 24, 2013, 12:40:17 AM »
« Reply #4 on: September 24, 2013, 03:19:05 AM »
Thanks Tweakie
Will head round to my local computor repair man and see what he has got.
Graham
« Reply #5 on: September 24, 2013, 04:20:47 AM »
Tweakie
Got a used one for free and it fits perfectly, now why didnt I think of that in the first place.
Thanks Graham
  •  9,374 9,374
« Reply #6 on: September 24, 2013, 07:56:09 AM »
Hi Graham,
I am pleased you got it sorted.  ;)
« Reply #7 on: September 25, 2013, 03:49:13 AM »
Tweakie
Just a thought
If I connect a momentary switch between the normally open and common on a limit switch so that when it trips from the normally closed position I can press it and press jog together to get off the stop?
Graham
  •  9,374 9,374
« Reply #8 on: September 25, 2013, 09:03:33 AM »
Hi Graham,
Not sure if that would work or not (never tried it).
I would think the best option would be to enable Auto Limit Override (Settings page). Tick this and it will allow you to jog off the stops (assuming you move in the correct direction ).  ;)
« Reply #9 on: September 25, 2013, 09:16:55 AM »
Tweakie
On a previous post of mine ref "limit switch" Ger21 said
"Mach3 won't move off a limit switch. You need to do that manually."
So if all I have to do is change some settings thats a lot easier.
Thanks Graham
PS
This is the post
http://www.machsupport.com/forum/index.php/topic,25482.0.html
