Hello Guest it is October 21, 2026, 10:55:10 AM
Author Topic: TB 6560 BOB LIMIT SWICH CONNECTIONS  (Read 18571 times)
  •  9,374 9,374
Re: TB 6560 BOB LIMIT SWICH CONNECTIONS
« Reply #10 on: September 25, 2013, 11:10:57 AM »
"Mach3 won't move off a limit switch. You need to do that manually."
Hi Graham,
Gerry is quite correct, once tripped it will not move under GCode control it will only move off the switch when jogging manually (keyboard etc.).
