Hello Guest it is November 22, 2026, 04:00:48 PM
Author Topic: Not working after update  (Read 28670 times)
« on: September 14, 2013, 08:34:13 AM »
Hi guys,
I just updated mach3 to the latest version and it's thrown a wobbly.  Basically, I done a 5 inch test cut but it  seems to go through the correct motions but cut approx. 5 mil.  I have been told to check gcode but it seems ok.  Is there anything in the config I need to look at.
regards
ps.  I am a comparative convert so simple talk would be appreciated.
Re: Not working after update
« Reply #1 on: September 14, 2013, 09:47:34 AM »
Config... native units... mm or in...
« Reply #2 on: September 14, 2013, 09:56:18 AM »
Hi
Thanks for the reply, I ve tried that and I also tried the "setting", "Set steps per unit" but the movement was so small the output was something like 20,000 to input into the motor tuning.  Obviously didn't work, Im thinking of a total uninstall and reconfig, unless someone suggest something easier.  Cheers
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: September 14, 2013, 10:20:25 AM »
please post both your gcode file and your xml file. (if you don't know where your xml file is or what it's called then look bottom right of your mach screen for "your profile name" - now look in c:\mach3 for "your profile name".xml. Now copy it to your desktop and rename it to daibeer.xml and attach it to your post (using the FULL reply "additional options" i.e. not the quick reply).
« Reply #4 on: September 14, 2013, 10:53:46 AM »
Thanks, will do asap
« Reply #5 on: September 14, 2013, 11:20:50 AM »
Have a look at  the first line of your program, if its got a g21 your program is in metric, if its g20 its imperial. If there isn't a G20 in put one in and see what happens. When I first loaded the latest update it did it in metric and all the programs I wrote were in metric although I thought I was doing them in Imperial. Just a thought. But be careful as I'm not sure what it will do to your feed rate!! Jim
« Last Edit: September 14, 2013, 11:24:21 AM by jimthefish »
« Reply #6 on: September 14, 2013, 11:41:57 AM »
Hi
Having a problem sending post with att. files so I'll wait half an hour and try again
« Reply #7 on: September 14, 2013, 12:12:33 PM »
Hi
Trying file 1
« Reply #8 on: September 14, 2013, 12:14:03 PM »
Hi
Here's file 2.  Also details of my machine:
High-Z S-1000/T
Milling machine HIGH-Z S-1000/T:
Same as HIGH-Z S-720 and S-400 but:
• Drive : 4 stepping motor by Nanotec with 1600 steps/rev   (1/8 Step)
• 2 motors for constant traction and compressive forces while milling on the X-axle
• Feed through of long workpieces possible, because there’s no belt drive at the end of the X-axle
• Guide ways X and Y axle 22mm, Z= 16mm, grinded and with hardened surface
• Ball bearings at both sides of  ballscrews on X and Y axle
• Traverse speed max. 7.000 mm/min
•Technical resolution 0,00625 mm ( 1/8 step )
•Clamping area 1300 x 700 mm
•Traverse paths: X=1000 mm; Y=580 mm; Z= 110 mm
•Reference / end switches on all axis
•Dubble safed emergency shut down
•Energy chains for neat cable conduit
•Total dimensions incl motors : LxBxH=approx. 1350x840x500mm
•Milling motor anchorage: Euroneck Ø 43mm
•incl. software PC-NC or WIN PCNC Light
•Modular frame for universal application
•Weight appr. 51 kg
• Complete machine incl 4 channel controlling 4x 2.1 Ampere
Hope this helps
Offline stirling
  •  2,188 2,188
  • UK
« Reply #9 on: September 14, 2013, 12:50:28 PM »
OK - your gcode is fine in as much as it has G20 - so inch units (and your default units are inch). However have a word with whoever wrote your post and ask them to fix their space bar - either that or ask them iftheywritesentenceslikethisaswell.
Anyway - according to your specs you have screws with a 10mm lead and a microstepping factor of 8 and standard 1.8 degree steppers so your steps/per (inch) in motor tuning should be 4064 if my maths is correct.
Ian
