Hello Guest it is November 22, 2026, 04:00:53 PM
Author Topic: Not working after update  (Read 28672 times)
Re: Not working after update
« Reply #10 on: September 14, 2013, 01:08:32 PM »
Hi
Is 4064 acceptable in the motor tuning? The norm appears to be around 266 in all the tutorials.  Don't want it to kill itself?
« Reply #11 on: September 14, 2013, 01:22:17 PM »
I use 10160 for 3 of my axis and 200 for a axis...     See your info from manufacturer....
« Reply #12 on: September 14, 2013, 03:02:59 PM »
Steps per unit will be whatever your hardware dictates, likely the tutorials  you have been seeing are metric setups where the steps per unit will be 25.4 times smaller than Imperial setups as there are 25.4 mm's in an inch.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #13 on: September 15, 2013, 02:21:31 AM »
Hi
I've done this a couple of times before - I wouldn't have given you it if I thought it was incorrect or "dangerous".  ;)
According to the specs you gave this is correct - and no damage would occur whatever number you put in - it just wouldn't travel the correct distance.
Ian
« Reply #14 on: September 15, 2013, 04:32:09 AM »
Hi
Thanks a lot, I'll give it a go a bit late on after breakfasts,
regards
« Reply #15 on: September 15, 2013, 07:23:33 AM »
Hi all,
Firstly, many thanks for everyones help, it is really appreciated.  I managed to get things sorted by a complete uninstall followed by in install.  Don't know why or what happened, but it seemed to do the trick.
Thanks again everyone.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #16 on: September 15, 2013, 08:48:25 AM »
...and the steps/per are?
« Reply #17 on: September 16, 2013, 11:53:45 AM »
Hi
Sorry for the delay in answering.  I used the auto setup in settings to get the steps count.  The one where you put in the amount of distance to travel and input how far it actually travelled and ive got it very close as I'm only doing relief carvings so the steps count was 6800.  Hope this is what you wanted.
regards
Offline stirling
  •  2,188 2,188
  • UK
« Reply #18 on: September 17, 2013, 08:36:28 AM »
Curious number indeed... It just doesn't align (anywhere close) with the specs you posted - neither does it align particularly closely with any pitch of ballscrew I've come across - metric or Imperial.
That said a quick google results in at least 4 different specs for the "High-Z S-1000/T" depending on where you buy it. So maybe you have the 5th. ;D
Ian
