Hello Guest it is November 23, 2026, 11:40:01 PM
Author Topic: Spindle Speed Issues W/ Mach3  (Read 10292 times)
« on: August 29, 2013, 01:54:31 PM »
I am having issues with the spindle speed... I have attached the spindle config image and here are the issues:
1) With the current config spindle does not hardly spin faster than 5K even if it is specified to spin at 10k, 12k, etc.
2) I changed the PWMBase Freq. to 65 and the spindle will spin at about 10-12k but will not change even if specified (like above)
Is the something I am missing or a config change I should make??
(Just to note: we have a 5hp spindle with an 18k RPM max)
Thanks in advance!!
Re: Spindle Speed Issues W/ Mach3
« Reply #1 on: August 29, 2013, 05:00:25 PM »
Post your .xml file if you can.
« Reply #2 on: August 30, 2013, 06:26:03 AM »
Check to make sure the drive is setup properly for max spindle motor speed.
« Reply #3 on: September 12, 2013, 03:32:37 AM »
Check that motor is tuned properly in config/motor tuning/spindle.  Either steps per or velocity needs tweaking.  Also your BOB may be a bit different.  Make sure you are getting full voltage out of your BOB.
