Hello Guest it is November 22, 2026, 10:19:57 AM
Author Topic: Rotary Table  (Read 9504 times)
Rotary Table
« on: August 20, 2013, 02:23:24 PM »
Hi All
I want my rotary table to act as a pull roller to pull a paper roll through a set ditance.
Is it acceptable to change the motor settings to achive a 1" pull for 1degree dro readout,
I have done the calculations and I need to go from 66.666666 steps for normal 360deg rotation to  2748  for a 2.78" dia and 1" pull
2.78*3.142/360=.02426 for 1 deg (normal)
so 1" is 66.666666/.02426 or 2748 steps with approprate change to speed and accelaration
It seems to move the correct distance but are there any problems with this?
Graham
Re: Rotary Table
« Reply #1 on: August 20, 2013, 03:11:57 PM »
Set the rotary axis to a linear axis in General Config and you should be fine.
Re: Rotary Table
« Reply #2 on: August 20, 2013, 06:52:42 PM »
Set up as linear drive and then calculate the steps based on the circumference of the roller. Then you can use the axis X or Y directly same as a normal axis. It would just have have an infinite distance.
Re: Rotary Table
« Reply #3 on: August 21, 2013, 03:43:56 AM »
TP & HOOD
Thanks for your advice.
Graham
