Hello Guest it is November 22, 2026, 09:06:57 AM
Author Topic: RefAllHome vs motor tuning vs Homing/Limits  (Read 9639 times)
« on: August 18, 2013, 10:03:29 PM »
HI ! I'm new here as with mach3 and found a relation between homing/Limits, Motor Tuning and RefAllHome.
when I press ' REFALLHOME '; I get no motor moving on individual axis if velocity value set to 30 or lower,but works fine over-it ...
- Same thing happen for homing/limit _ speed%  less then 15 ... is-it normal ?
 Someone can confirm this or explain me ?
Re: RefAllHome vs motor tuning vs Homing/Limits
« Reply #1 on: August 19, 2013, 01:47:45 AM »
Attach your xml please and I will test with it.
« Reply #2 on: August 22, 2013, 11:49:39 AM »
I reviewed  my home/limit values and they were badly set cause
 all is working'  nickel ' with any velocity or acceleration values. The proof that Mach won't let me do wrong things.
 :o and thanks for this fast reply.
