Hello
Guest
it is
October 21, 2026, 03:45:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Does the "Angle Slot Cutter Rev. 2.4" work?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Does the "Angle Slot Cutter Rev. 2.4" work? (Read 9838 times)
DICKEYBIRD
436
on:
August 18, 2013, 09:36:56 AM »
Haven't used Mill much so it's probably my ignorance but I can't get this wiz to work. I just need a couple angled slots but the generated code just plunges the Z axis a few times with no X-Y moves at all.
Here's the code & I attached a shot of the wiz screen.
Thanks for lookin'
Milton
G20
G17 G40 G80
G00 Z0.2
G90 G54
S3000 M03
(insure IJ mode is incremental)
G91.1
G00 Z0.2
G00 X-1.8 Y-0.85
M9
G00 Z0.1
G01 Z0 F10
(plunge - center cut)
G20
G17 G40 G80
G00 Z0.2
G90 G54
S3000 M03
G91.1
G00 Z0.2
G00 X-1.8 Y-0.85
M9
G00 Z0.1
G01 Z0 F10
Milton from Tennessee ya'll.
BR549
6,965
Re: Does the "Angle Slot Cutter Rev. 2.4" work?
Reply #1 on:
August 18, 2013, 10:11:50 AM »
It works here I just tried it.
DICKEYBIRD
436
Reply #2 on:
August 18, 2013, 10:24:23 AM »
Thanks BR; did you input the same numbers I used? If so, it must be something in my mill config or ??
I know nothing yet about cutter compensation. Could it be something I need to config to make it work...or does that wiz even use it.
DICKEYBIRD
436
Reply #3 on:
August 19, 2013, 12:03:59 PM »
Silly me.
I clicked the "Ramp" button and the wiz & worked flawlessly. Dunno why it won't when "Plunge" is selected but I'm happy any way.
Print
Pages:
1
Go Up
« previous
next »
