Hello Guest it is October 24, 2026, 05:27:04 PM
Author Topic: Spindle starts on closing Mach  (Read 46456 times)
Re: Spindle starts on closing Mach
« Reply #10 on: July 29, 2013, 03:43:32 PM »
Ok the manual says it converts a step signal to a PWM  but the diagrams are misleading, either that or I am not reading it right.
It says to set the spindle to Step/Dir motor yet the pic shows it set to PWM.
Have you tried it set to Step/Dir motor?
Offline mvoros
  •  141 141
« Reply #11 on: July 29, 2013, 04:03:12 PM »
No I have not, because Arturo always said to set it to PWM. I'll try that tomorrow.
Thanks Hood.
« Reply #12 on: July 29, 2013, 04:18:11 PM »
That is what I just dont follow, the manual seems all mixed up or at least it reads mixed up to me, maybe I just speak/read a different language :D
Offline mvoros
  •  141 141
« Reply #13 on: July 30, 2013, 06:24:40 AM »
Have you had a chance to look at my xmxl yet. Is there a problem there?
Mike
Offline mvoros
  •  141 141
« Reply #14 on: July 30, 2013, 07:23:02 AM »
Hi Hood,
Here is the email I got from Arturo last week. When I asked him why can't he show me the connections on my vfd's sketch I sent him, well I haven't heard from him since.
Mike
« Reply #15 on: July 30, 2013, 07:24:22 AM »
Never saw anything wrong in the xml, well that depends on how you see things in the manual for the C41, looking at it in the pic you have it similar, if reading the text then it is wrong as it says to set up as a step/dir motor.
« Reply #16 on: July 30, 2013, 07:28:46 AM »
Basically what Arturo had in pic 2 should work if  the C41 is as he says in the manual but again it shows in pics to set as PWM but in text as Step/Dir. So ...... well I can only suggest you ignore the pic and try the text and see. If it still doesnt work when you connect as per pic 2 then afraid I have no idea.
An option would be to use an external relay to connect the  Fwd and CM and energise the relays coil from Spindle Relays in Mach rather than via the C41.
Offline mvoros
  •  141 141
« Reply #17 on: July 30, 2013, 08:58:14 AM »
Thanks Hood. I'll get back to you on that.
Mike
Offline rdean
  •  94 94
« Reply #18 on: July 30, 2013, 01:24:21 PM »
Or you could use a charge pump to connect Fwd to CM.
Ray
Offline mvoros
  •  141 141
« Reply #19 on: July 31, 2013, 03:18:19 PM »
To continue this spindle saga.
What I have done in the last 30 hours. Removed mach3 and all associated programs, Plugins, Brains. Did a clean up and compression of my drive. Loaded Mach3 R 3.043.066 version up, ESS plug in v 10hd2, MPG Brain. Reconfigured Mach. The saved xml didn't load my previous settings up, so I started from scratch. For the spindle, tried step/dir instead of PWM both on the ports/pins spindle set up page and the ESS's page. By the way, I wired the VFD and The C41 the way Arturo insisted I should connect them. The spindle excepts speed commands, and stops on M5, the Relay doesn't click. However, when I exit from Mach it starts up and keeps cycling, the Relay is clicking on/off. When I open Mach the spindle stops. I went back to setting the everything back to PWM, but the same exact thing happens. I'm attaching my wiring diagram, in the hope, that someone takes a careful look at it and tell me if it is wrong. I had Arturo and Hood look at it and they both say it should work. Go figure. I did find a guy on the forum that had similar problems, but I can't find him any more. The most frustrating thing in all this is, that I can't find anybody to send me back my own drawing with the wiring corrected. Is that such a big deal, I ask? Here is hoping someone’ll get me out of this hole. Please, no fancy technical words, just a simple diagram, or explanation.
Mike
« Last Edit: July 31, 2013, 03:19:54 PM by mvoros »
