Hello Guest it is November 13, 2026, 02:29:31 PM
Author Topic: Gecko Drive and A axis indexer question  (Read 8769 times)
Offline P_D_B
  •  35 35
« on: June 15, 2013, 07:27:16 PM »
I want to get a Gecko 203V for the A axis I am building.  My question is how does Mach send the signals, would I need to get the CW\CCW drive rather than the standard Step\Dir?
Thanks in advance.
Remember Einstein said this...."We can't solve problems by using the same kind of thinking we used when we created them."
__________________________________
Pete
Re: Gecko Drive and A axis indexer question
« Reply #1 on: June 15, 2013, 08:00:12 PM »
The G203V takes standard Step/Dir signals from Mach3. The A axis (rotary) is driven similar to the standard XYZ linear axes except the movement is specified in degrees rather than inches or mm.
To turn clockwise  increase the angular value i.e. A45 moves the axis to the 45 deg position.
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
