Hello Guest it is November 01, 2026, 10:12:21 AM
Author Topic: Tool offset problems  (Read 41918 times)
Offline Psad
  •  82 82
« on: February 18, 2007, 12:54:29 PM »
I have an old problem that has come back.  Downloaded mach3 and Lcam today (sunday 2/18).
Ran an old part with minor charges and sent to G-code. LC did not put G41 or G42 into the G-code file.
Is calls for a tool change but did not add the offset Gcodes.  they should be in there no matter what.
Correct.
Re: Tool offset problems
« Reply #1 on: February 24, 2007, 05:12:55 PM »
I will have a look at it but it will have to be after Art is done adding the pocketing  code.
Did you have G41/42 turned on in the posting options?
www.newfangledsolutions.com
www.machsupport.com
Offline Psad
  •  82 82
« Reply #2 on: February 25, 2007, 06:32:59 AM »
Brian I checked the posting options and yes it is checked.  I even unchecked and rechecked it to make sure.  Everyting seems ok except no g41 or 42.  Here is the Lcam project file and the Gcode file.
Also Art what does R represent in the G81 code.
I keep getting R < z in line 8
You guys are doing a great job it is fantastic to have such good support
Sorry I got kicked out on the first try.
This would not let me send an Lcam file.
YOu might want to change that.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: February 25, 2007, 04:34:51 PM »
Hi, Psad
You also need to turn "Leadin on"  on each line segment, click on line, double click on start point, window opens to set it?
Probably now this, just didn't mention it in your post.
Hope this Helps, Chip
Offline Psad
  •  82 82
« Reply #4 on: February 26, 2007, 07:03:46 AM »
nope that is not it  lead ins are on and set to 25% circular
Wierd - I've had a problems with this before.  Even set out a couple of posts.
Offline Chip
  •  2,055 2,055
« Reply #5 on: February 26, 2007, 09:25:59 PM »
Hi, Psad
Just posted some code hear with ver Msch3r2.0.049, LC ver 2.00.037, Posted G41's for me.
Is your lead-in = to or grater than 1\2 your cutter Dia. ?
Haven't a Clue, Chip ( some will agree on that)
Offline Psad
  •  82 82
« Reply #6 on: February 28, 2007, 06:28:41 AM »
Yes, I'm using .25 units (inches)  and a .25" cutter.
I can't figure it out  Still trying
Offline Chip
  •  2,055 2,055
« Reply #7 on: February 28, 2007, 02:09:33 PM »
Hi, Psad
Ver. 2.0.050 is on line Art stated it has updated LC in it.
O--well don't Now, Chip
Offline Psad
  •  82 82
« Reply #8 on: March 01, 2007, 10:13:59 AM »
New versoin defaults to plasma mode and cannot turn off.  No tool changes like this, so I cannot check the G41 G42 issue.
Offline Chip
  •  2,055 2,055
« Reply #9 on: March 01, 2007, 12:32:41 PM »
Hi, Psad
Hear is the latest LC, even though it says, N20 (Default Plasma Post), It post's g42 for me.
I used the Auto In-side out-side option, with plasma un selected.
N10 (File 375 chain chuteSINGLEDXF Test File )
N30 (File Posted in Mill Mode)
N40 (Thursday, March 01, 2007)
N50 G90
G80 G40 G91.1
N60 G0  Z0.0000
N70 G0  X1.6450  Y0.2579
N80 G0  Z0.1000
N90 M3 (PLasma On)
N100 G1  Z0.0000
N110 G42
N120  X1.6450  Y0.0000
N130 G2  X0.0945  Y0.8055  I-0.0000  J1.8950
N140  X0.0000  Y1.1044  I0.4255  J0.2990
N150 G1  Y2.6856
N160 G2  X0.0945  Y2.9845  I0.5200  J-0.0000
N170  X0.2125  Y3.1355  I1.5505  J-1.0895
N180 G1  X1.0163  Y4.1530
N190 G2  X1.6450  Y4.4850  I0.6287  J-0.4293
N200  X2.2737  Y4.1530  I-0.0000  J-0.7613
N210 G1  X3.0775  Y3.1355
N220 G2  X3.1955  Y2.9845  I-1.4325  J-1.2405
N230  X3.2900  Y2.6856  I-0.4255  J-0.2990
N240 G1  Y1.1044
N250 G2  X3.1955  Y0.8055  I-0.5200  J0.0000
N260  X1.6450  Y0.0000  I-1.5505  J1.0895
N270 G40
N280 G1  X1.6450  Y0.2579
N290 M5 (Plasma Off)
N300 G00  Z0.0000
N310 M5 M9
N320 X0.0 Y0.0
N330 G40 G80
M30
This one with out auto selected, with plasma un selected.
N50 G90
G80 G40 G91.1
N60 G0  Z0.0000
N70 G0  X-0.2587  Y1.1073
N80 G0  Z0.1000
N90 M3 (PLasma On)
N100 G1  Z0.0000
N110 G42
N120  X0.0000
N130  Y1.1044
N140 G3  X0.0945  Y0.8055  I0.5200  J-0.0000
N150  X3.1955  Y0.8055  I1.5505  J1.0895
N160  X3.2900  Y1.1044  I-0.4255  J0.2990
N170 G1  Y2.6856
N180 G3  X3.1955  Y2.9845  I-0.5200  J0.0000
N190  X3.0775  Y3.1355  I-1.5505  J-1.0895
N200 G1  X2.2737  Y4.1530
N210 G3  X1.6450  Y4.4850  I-0.6287  J-0.4293
N220  X1.0163  Y4.1530  I-0.0000  J-0.7613
N230 G1  X0.2125  Y3.1355
N240 G3  X0.0945  Y2.9845  I1.4325  J-1.2405
N250  X0.0000  Y2.6856  I0.4255  J-0.2990
N260 G1  Y1.1073
N270 G40
N280  X-0.2587
N300 G00  Z0.0000
N310 M5 M9
N320 X0.0 Y0.0
N330 G40 G80
M30
Seems to work Hear, Chip
