Hello Guest it is November 13, 2026, 11:39:15 AM
Author Topic: no power to z  (Read 35892 times)
Re: no power to z
« Reply #10 on: May 20, 2013, 03:15:36 PM »
I don't know where the jog page up and down is
Re: no power to z
« Reply #11 on: May 20, 2013, 03:18:46 PM »
Under Config / System HotKeys.
You also have the X axis backwards there.
The Fly-out Pendant pops up with the TAB key.
Russ
Re: no power to z
« Reply #12 on: May 20, 2013, 03:41:53 PM »
ok     The mach 3 and your sim is running like z is moving.   smoothstepper dia thinks z is moving.   no power to z.    is that a controller problem ?
or my xml ?
Re: no power to z
« Reply #13 on: May 20, 2013, 04:06:05 PM »
Do you mean "no power to the motor ? is it a stepper ? is it holding firm ?
or, do you mean there is "no pulse stream to the drive ?
The xml looks ok at a glance, but like Hood said, does you physical wiring match your pin assignments in the SW for the Z ?
Re: no power to z
« Reply #14 on: May 20, 2013, 04:11:48 PM »
z spins, does not get tight when controller starts
Re: no power to z
« Reply #15 on: May 20, 2013, 04:17:50 PM »
Steppers or servos ?
Is there an "enable" for the drive ?
Did you try one of the other drives with the Z axis motor ?
Did you try the Z axis motor with one of the other "working" drives ?
Not sure what you meant by " I changed the z to x and x did not work".
Re: no power to z
« Reply #16 on: May 20, 2013, 05:08:02 PM »
Did you try one of the other drives with the Z axis motor and Z's configuration ?
Did you try the Z axis motor with one of the other "working" drives and it's configuration ?
Re: no power to z
« Reply #17 on: May 20, 2013, 05:25:57 PM »
yes and if I put new motor on z it does not work
and connect z wire to x it does not work
Re: no power to z
« Reply #18 on: May 21, 2013, 06:08:23 AM »
Ok here is what I suggest you try. Connect the physical wiring that goes from your breakout to X drive to your Z drive then in Mach Jog the X. If the Z moves then your hardware is ok, if it doesnt then setup or SS or Bob is wrong.
Re: no power to z
« Reply #19 on: May 22, 2013, 12:06:53 PM »
I have replaced the motor still z does not lock.
Mach3 shows movement and smoothstepper diag shows movement.
When I change the position of z in mach3, then regen the code changes but no z movement.
I believe my problem is the controller or the smoothstepper driver Ver 17efb, 37, 2.08.36.
