Hello
Guest
it is
November 24, 2026, 04:06:46 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
no power to z
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: no power to z (Read 36038 times)
jayybone
21
Re: no power to z
Reply #20 on:
May 22, 2013, 12:50:34 PM »
I had the exact same problem. Only I would have power to Z (could not spin screw) then as soon as i tried to move Z, mach would show it moving but the motor would lose power instantly (could then move screw after pushing pgup/pgdn) I have replaced the driver on the controller to see if that works but have not tested yet. I will not be able to test a couple days because i am leaving town but i will let you know as soon as i return and test it out. I have a HobbyCNC Pro board. After reading yours it sounds as though we may be having the exact same issues.
Here is a thread that i started for this issue as well. See if what they had to say could help you.
http://www.machsupport.com/forum/index.php/topic,24465.0.html
Logged
moxietek@aol.com
22
Re: no power to z
Reply #21 on:
May 22, 2013, 12:55:43 PM »
TY very much
Logged
Carnoustie, Scotland
Re: no power to z
Reply #22 on:
May 22, 2013, 05:05:02 PM »
Have you tried as I said in post 18?
Logged
jayybone
21
Re: no power to z
Reply #23 on:
May 29, 2013, 04:08:29 PM »
My similar problem was corrected after I replaced the driver chip. I would recommend trying this also!
Logged
moxietek@aol.com
22
Re: no power to z
Reply #24 on:
May 29, 2013, 04:17:37 PM »
I put x on z of the controller and x jogs but z will not no matter where I hook it
Logged
Re: no power to z
Reply #25 on:
May 29, 2013, 04:20:42 PM »
But what X and Z, are you just swapping the motor wiring or are you swapping the wiring to the drives themselves?
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
