Hello Guest it is November 03, 2026, 08:47:16 AM
Author Topic: Need a little help  (Read 11136 times)
Need a little help
« on: February 14, 2007, 09:22:11 AM »
Basically Im not getting any movement out of anything. I tried to run the Road Runner Example, I have tried to jog. I tried to do a simple box from Lcam and nothing is working. I have watched pretty much all of the video's and have even set it up just like Art did and still nothing. Also when I use Lazy Cam it reads to the 6th line in the gcode box but when I run the road runner example it doesnt leave the first line. And the numbers do not get larger or smaller in the Machine Coordinates window either.  I missing something? Thanks for any help. Josh
« Last Edit: February 14, 2007, 09:30:38 AM by Regnar »
"Sue Sponte"
Re: Need a little help
« Reply #1 on: February 14, 2007, 09:37:59 AM »
What do you see in the Time in int dro on the diagnostics screen?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 14, 2007, 09:55:06 AM »
It flashes between 1.8 and 2.0
"Sue Sponte"
« Reply #3 on: February 14, 2007, 09:59:42 AM »
Sometimes its just better to start all over again.  ;D I reinstalled Mach 3 on my Computer and everything works great. Gcode Runs and Jog works. I should have done this 2 days ago but I truley thought I had missed something. Knowing me I probably clicked on something I wasnt suppose to. Thanks for looking into it Brian.
"Sue Sponte"
