Hello
Guest
it is
October 21, 2026, 10:00:17 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
M6 Macro working when I romove gcode line #s
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: M6 Macro working when I romove gcode line #s (Read 11042 times)
Fleck
31
on:
April 21, 2013, 07:48:14 PM »
Hi is there some text I can insert into my tool-change macro to account for the line #s my CAM has in its code. My tool change works if I delete them.
this is my router, there are many like it but this one is mine
ger21
6,295
Re: M6 Macro working when I romove gcode line #s
Reply #1 on:
April 21, 2013, 08:18:21 PM »
Can you be more specific about what the problem is?
What version of Mach3 are you using?
Fleck
31
Reply #2 on:
April 21, 2013, 08:43:39 PM »
Yes, sorry. The block line numbers like
;NO3
T1 M6 . Actually it is the semicolon in front of the block line numbers that is causing the issue. I am using .066
ger21
6,295
Reply #3 on:
April 21, 2013, 09:14:58 PM »
You need to edit the post processor to get rid of the semicolons.
Fleck
31
Reply #4 on:
April 21, 2013, 11:12:15 PM »
OK thanks.
Print
Pages:
1
Go Up
« previous
next »
