Hello Guest it is November 22, 2026, 05:48:49 PM
Author Topic: M6 Macro working when I romove gcode line #s  (Read 11397 times)
Offline Fleck
  •  31 31
    • fleckguitar.com
« on: April 21, 2013, 07:48:14 PM »
Hi is there some text I can insert into my tool-change macro to account for the line #s my CAM has in its code. My tool change works if I delete them.
this is my router, there are many like it but this one is mine
Re: M6 Macro working when I romove gcode line #s
« Reply #1 on: April 21, 2013, 08:18:21 PM »
Can you be more specific about what the problem is?
What version of Mach3 are you using?
Offline Fleck
  •  31 31
    • fleckguitar.com
« Reply #2 on: April 21, 2013, 08:43:39 PM »
Yes, sorry. The block line numbers like  ;NO3 T1 M6 . Actually it is the semicolon in front of the block line numbers that is causing the issue. I am using .066
« Reply #3 on: April 21, 2013, 09:14:58 PM »
You need to edit the post processor to get rid of the semicolons.
Offline Fleck
  •  31 31
    • fleckguitar.com
« Reply #4 on: April 21, 2013, 11:12:15 PM »
 OK thanks.
