Mach Discussion => General Mach Discussion => Topic started by: Fleck on April 21, 2013, 08:48:14 PM
Hi is there some text I can insert into my tool-change macro to account for the line #s my CAM has in its code. My tool change works if I delete them.
Can you be more specific about what the problem is?
What version of Mach3 are you using?
Yes, sorry. The block line numbers like ;NO3 T1 M6 . Actually it is the semicolon in front of the block line numbers that is causing the issue. I am using .066
You need to edit the post processor to get rid of the semicolons.
OK thanks.
