Hello
Guest
it is
November 13, 2026, 11:20:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Disable Sound
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Disable Sound (Read 69450 times)
Kenneth
279
Disable Sound
on:
April 01, 2013, 01:33:05 PM »
is there a way to disable sound in mach3 Version R3.043.062 ?
tired of the hum/click noise i get when i click buttons or open a
new set file.
Thanks !
Kenneth
BR549
6,965
Re: Disable Sound
Reply #1 on:
April 01, 2013, 01:47:55 PM »
Config/GenConfig/ Off center to the right ,center of page.
Use Key Clicks
Kenneth
279
Re: Disable Sound
Reply #2 on:
April 01, 2013, 01:50:30 PM »
thanks TP,
is it suppose to be checked ? it's not.
Kenneth
BR549
6,965
Re: Disable Sound
Reply #3 on:
April 01, 2013, 04:58:57 PM »
Must be broken then, if checked you get key clicks if not you should not get anything.
Just a thought, (;-) TP
BR549
6,965
Re: Disable Sound
Reply #4 on:
April 01, 2013, 05:13:15 PM »
IF you are talking about the sounds like IF you press RESET those are windows sounds just hit the MUTE button on your volume control.
Kenneth
279
Re: Disable Sound
Reply #5 on:
April 02, 2013, 04:55:25 AM »
thanks TP,
i am talking about the reset button also. but i use the window
sound for other programs.
Kenneth
Kenneth
279
Re: Disable Sound
Reply #6 on:
April 02, 2013, 05:54:27 AM »
did a run-a-round.
disabled exclaimation in win sound.
hope this gets fix in newer vesion.
Thanks TP
Kenneth
Kenneth
279
Re: Disable Sound
Reply #7 on:
April 02, 2013, 06:56:43 AM »
also,is there a way to disable the "Are You Sure?"
exit message in mach3 ?
Kenneth
Kenneth
279
Re: Disable Sound
Reply #8 on:
April 02, 2013, 10:38:42 AM »
what about another "Error" label. trying to use to get
send massage different area then current area of the label
and don't want to send error messages.
Kenneth
BR549
6,965
Re: Disable Sound
Reply #9 on:
April 02, 2013, 09:11:40 PM »
Kenneth ALL you do to mute the sound is click on the windows sound icon on the RH lower toolbar then push the mute button. Then when you want sound just uncheck the mute button.
You can place a user label anywhere you want and send messages to it. Check the Mach Customising manual for details.
(;-)TP
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
