Hello Guest it is November 13, 2026, 11:29:33 AM
Author Topic: Disable Sound  (Read 69456 times)
Disable Sound
« on: April 01, 2013, 01:33:05 PM »
is there a way to disable sound in mach3 Version R3.043.062 ?
tired of the hum/click noise i get when i click buttons or open a
new set file.
Thanks !
Kenneth
Re: Disable Sound
« Reply #1 on: April 01, 2013, 01:47:55 PM »
Config/GenConfig/  Off center to the right ,center of page.
Use Key Clicks
Re: Disable Sound
« Reply #2 on: April 01, 2013, 01:50:30 PM »
thanks TP,
is it suppose to be checked ? it's not.
Kenneth
Re: Disable Sound
« Reply #3 on: April 01, 2013, 04:58:57 PM »
Must be broken then, if checked you get key clicks if not you should not get anything.
Just a thought, (;-) TP
Re: Disable Sound
« Reply #4 on: April 01, 2013, 05:13:15 PM »
IF you are talking about the sounds like IF you press RESET those are windows sounds just hit the MUTE button on your volume control.
Re: Disable Sound
« Reply #5 on: April 02, 2013, 04:55:25 AM »
thanks TP,
i am talking about the reset button also. but i use the window
sound for other programs.
Kenneth
Re: Disable Sound
« Reply #6 on: April 02, 2013, 05:54:27 AM »
did a run-a-round.
disabled exclaimation in win sound.
hope this gets fix in newer vesion.
Thanks TP
Kenneth
Re: Disable Sound
« Reply #7 on: April 02, 2013, 06:56:43 AM »
also,is there a way to disable the "Are You Sure?"
exit message in mach3  ?
Kenneth
Re: Disable Sound
« Reply #8 on: April 02, 2013, 10:38:42 AM »
what about another "Error" label. trying to use to get
send massage different area then current area of the label
and don't want to send error messages.
Kenneth
Re: Disable Sound
« Reply #9 on: April 02, 2013, 09:11:40 PM »
Kenneth ALL you do to mute the sound is click on the windows sound icon on the RH lower toolbar then push the mute button. Then when you want sound just uncheck the mute button.
You can place a user label anywhere you want and send messages to it. Check the Mach Customising manual for details.
(;-)TP
