Hello Guest it is November 13, 2026, 09:42:53 AM
Author Topic: Disable Sound  (Read 69432 times)
Re: Disable Sound
« Reply #20 on: April 04, 2013, 11:03:58 AM »
Kenneth try a new label and call it MDI  When Mach3 changes state of the G20/21 it will show Inches, MM
Re: Disable Sound
« Reply #21 on: April 04, 2013, 11:22:07 AM »
i know, wanted to not have those in this label.
is there a UserMDI1 ? :)
Kenneth
Re: Disable Sound
« Reply #22 on: April 04, 2013, 11:23:27 AM »
the user label ?  UserLabel1
Hallo Kenneth,
what text did you set to your label?
Klaus
Kenneth
Re: Disable Sound
« Reply #23 on: April 04, 2013, 02:04:59 PM »
set the text you want to have displayed in the property dialog.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Disable Sound
« Reply #24 on: April 08, 2013, 04:42:11 AM »
if i use Inch and not UserLabel1, it will just be a label.
i want it to change as i click the Convert button.
unless i don't understand which lael you mean.
Kenneth
Re: Disable Sound
« Reply #25 on: April 08, 2013, 05:14:45 AM »
a better picture
Metric =  UserLabel1
12.000 = user input dro
Convert = button
led = user led
Lit is MM = stand label
Kenneth
Re: Disable Sound
« Reply #26 on: April 08, 2013, 05:51:54 AM »
also...is there a way to change/enlarge the font on buttons(without enlarging the button) ?
ie. Convert above
« Last Edit: April 08, 2013, 05:55:21 AM by Kenneth »
Kenneth
Re: Disable Sound
« Reply #27 on: April 08, 2013, 11:08:15 AM »
Hi Kenneth,
write a macro containing:
SetUserLabel(nr, "text")
where text would be the default (Inch / metric).
Put that macro in the General Logic configuration  Initialization String field.
Klaus
Re: Disable Sound
« Reply #28 on: April 08, 2013, 11:12:19 AM »
i have this....
but do you mean to write SetUserLabel(1,"Inch/Metric") ?
and it will pick between the two words ?
If GetUserLED(1012) Then
SetUserDRO(1010 , GetUserDRO(1010) / 25.400)
SetUserLabel(1,"Inch")  'displays Inch
SetUserLED(1012,0)
Else
SetUserDRO(1010 , GetUserDRO(1010) * 25.400)
SetUserLabel(1,"Metric")   'displays Metric
SetUserLED(1012,1)
End If
End
Kenneth
Re: Disable Sound
« Reply #29 on: April 08, 2013, 12:58:06 PM »
Hi Kenneth,
no, you must use the initialization text, either Inch or metrics.
Klaus
