Hello
Guest
it is
September 29, 2026, 04:28:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
FAQs
Motor Trouble
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Motor Trouble (Read 55689 times)
Overloaded
4,923
Re: Motor Trouble
Reply #30 on:
April 10, 2013, 06:27:13 PM »
OK, if you would post that dxf we can see how it loads in LCam here and mght see what the problem is and maybe give you some guidance.
Russ
Overloaded
4,923
Re: Motor Trouble
Reply #31 on:
April 10, 2013, 06:44:08 PM »
Ah, I vaguely remember LCam not seeing a lot of text from cad.
Needs to be a stick font ... or, true type ... or something.
I don't completely recall.
Navyboy007
10
Re: Motor Trouble
Reply #32 on:
April 10, 2013, 08:00:23 PM »
I hope I get this right? here goes I'm sending you the .dxf file from bobcad that I saved as a .dxf file, then loaded to Lcam. Thanks for your help Russ.
Jim
Overloaded
4,923
Re: Motor Trouble
Reply #33 on:
April 10, 2013, 08:35:47 PM »
I converted the TEXT to ENTITIES.
Try this one (your spacing is off a bit)
Re: Motor Trouble
Reply #34 on:
April 10, 2013, 10:26:19 PM »
Here is another one you can play with using an .125" dia cutter.
Last Edit: April 10, 2013, 10:28:42 PM by RICH
Print
Pages:
1
2
3
4
Go Up
« previous
next »
