Hello Guest it is September 29, 2026, 05:47:42 PM
Author Topic: Motor Trouble  (Read 55704 times)
Re: Motor Trouble
« Reply #20 on: April 10, 2013, 07:19:49 AM »
Don't feel bad as i am still in the bushes looking for the ball...........
Re: Motor Trouble
« Reply #21 on: April 10, 2013, 07:55:01 AM »
thanks Rich
hi evryone
i wonder if i don't disturb you, i enter here to ask for motor trubles ,but i forget to ask if i stil welcome in your club ??
  •  9,374 9,374
Re: Motor Trouble
« Reply #22 on: April 10, 2013, 10:04:17 AM »
hi evryone
Hi zoheirlabibes,
It is now your club and yes you are extremely welcome here.
Re: Motor Trouble
« Reply #23 on: April 10, 2013, 10:59:09 AM »
thanks Tweakie.
its very kind,
i write a simple G-code to cut a square but the toolpath follow a curve when reach the square corner not a 90°
please help
  •  9,374 9,374
Re: Motor Trouble
« Reply #24 on: April 10, 2013, 11:20:16 AM »
Hi zoheirlabibes,
You could either run in Exact Stop mode (Config / General Config - Motion Mode - select Exact Stop)
or...
Increase your Acceleration Rates in Motor Tuning (Config / Motor Tuning) for either or both the X and Y axes (you may also have to reduce the Velocity settings as well).
Obtaining the best results can be pretty much a matter of getting the balance between Velocity and Acceleration just right.
Re: Motor Trouble
« Reply #25 on: April 10, 2013, 11:39:54 AM »
Ok, I'll try it (Exact stop)
acceleration is set automaticly by mach3 i'll see if i can force it ,thanks
Re: Motor Trouble
« Reply #26 on: April 10, 2013, 12:02:39 PM »
it works
but constant velocity seems to be smoother, especially for plasma cutting i believe.
balance between Velocity and Acceleration, tomorrow i'll test it in real conditions on the machine.
thanks
Re: Motor Trouble
« Reply #27 on: April 10, 2013, 05:13:33 PM »
Hi Everyone
I still have a problem with .DXF files I have a simple block with my last name (Stewart) in lcam when I convert to mach3 all I see is 3/4 of the last letter(T), but not the block or name.  Again do I need to be licenced for both mach3 & Lcam?
Jim
Re: Motor Trouble
« Reply #28 on: April 10, 2013, 05:22:10 PM »
Hey Jim,
  Post the dxf file you are using, Or, are you just doing the TEXT within LCam ?
Be aware of where you have the ORIGIN for your part.
Russ
Re: Motor Trouble
« Reply #29 on: April 10, 2013, 05:57:29 PM »
I have used BobCad ver. 24 to draw a signboard with my name "Stewart" then saved to bobcad as a .dxf file.  When I open it in Lcam it only shows the outer edges of the board.
Jim
