Hello Guest it is September 29, 2026, 04:29:08 PM
Author Topic: Motor Trouble  (Read 55691 times)
Re: Motor Trouble
« Reply #30 on: April 10, 2013, 06:27:13 PM »
OK, if you would post that dxf we can see how it loads in LCam here and mght see what the problem is and maybe give you some guidance.
Russ
Re: Motor Trouble
« Reply #31 on: April 10, 2013, 06:44:08 PM »
Ah, I vaguely remember LCam not seeing a lot of text from cad.
Needs to be a stick font ... or, true type ... or something.
I don't completely recall.
Re: Motor Trouble
« Reply #32 on: April 10, 2013, 08:00:23 PM »
I hope I get this right?  here goes I'm sending you the .dxf file from bobcad that I saved as a .dxf file, then loaded to Lcam.  Thanks for your help Russ.
Jim
Re: Motor Trouble
« Reply #33 on: April 10, 2013, 08:35:47 PM »
I converted the TEXT to ENTITIES.
Try this one (your spacing is off a bit)
Re: Motor Trouble
« Reply #34 on: April 10, 2013, 10:26:19 PM »
Here is another one you can play with using an .125" dia cutter.
« Last Edit: April 10, 2013, 10:28:42 PM by RICH »
