Hello Guest it is October 12, 2026, 08:37:34 AM
Author Topic: Smoothstepper port 3 pins?  (Read 14237 times)
« on: March 22, 2013, 10:39:18 AM »
Hi, does anybody know if you can use smoothstepper  port 3 input pins for single ended MPG connection and if so which can i use to connect two MPGs. They are currently connected to port  2 but i could really do with the port 2  inputs for other stuff?.
Many thanks
Scratch
Re: Smoothstepper port 3 pins?
« Reply #1 on: March 22, 2013, 11:48:23 AM »
You should be able to do that no problem.  The pin numbers are the same as for a Parallel port just have to choose to use 2-9 as inputs (like a parallel port) if you need those I think.
« Reply #2 on: March 23, 2013, 08:59:40 AM »
Thanks Brett, i'll give it a shot.
Scratch
