Third party software and hardware support forums. => SmoothStepper USB => Topic started by: scratch on March 22, 2013, 11:39:18 AM
Hi, does anybody know if you can use smoothstepper port 3 input pins for single ended MPG connection and if so which can i use to connect two MPGs. They are currently connected to port 2 but i could really do with the port 2 inputs for other stuff?.
Many thanks
Scratch
You should be able to do that no problem. The pin numbers are the same as for a Parallel port just have to choose to use 2-9 as inputs (like a parallel port) if you need those I think.
Thanks Brett, i'll give it a shot.
Scratch
