Hello Guest it is November 13, 2026, 12:31:47 PM
Author Topic: NFS Turn in version 57  (Read 14878 times)
Offline m4uk
  •  38 38
« on: March 01, 2013, 10:24:42 AM »
After programming any of the wizards and clicking the Do it button I cant see a graphical representation of the shape I should be cutting. I get the green cut lines drawn as the code runs but there is no shape to see if I have programmed it right.
Is there a way of making this work?
Re: NFS Turn in version 57
« Reply #1 on: March 07, 2013, 11:13:20 AM »
 Hi m4uk,
i think this is an issue in .057 Whats happen is that the displayed toolpath  is shiftet by the amount of the fixture or G52.
e.g. in G54 . When all  set to 0 then its is shown ok. That does not happen in .062
Alex
Offline m4uk
  •  38 38
« Reply #2 on: March 11, 2013, 04:34:49 AM »
If I swap to 62 will the turn wizards work OK?
« Reply #3 on: March 11, 2013, 06:23:58 AM »
I dont have an issue with 057 and the NFS wizards or general G Code showing in the toolpath.
Maybe attach your xml and I will see what its like here.
« Reply #4 on: March 11, 2013, 11:26:10 AM »
I have the same behavior here in 057.
yes.
Hood, did you try this?
G52 Z50
... your code here
M30
Alex
« Reply #5 on: March 11, 2013, 11:48:53 AM »
Do the wizards add a G52?
Regardless, I have just added a G52Z50 and again seems fine, see screenshot.
« Reply #6 on: March 11, 2013, 02:50:44 PM »
Just gone back to 057 and used a new xml
Put in 50 mm in g54 Fixture ( the same result like G52Z50 )
When you start the code You get this: ( see picture)
No. this was only for testing.
Alex
« Reply #7 on: March 11, 2013, 04:23:19 PM »
Not really sure what you are meaning by "Put in 50 mm in g54 Fixture " If you are meaning you entered 50 into the Z DRO then I tried that here and again fine, not sure where the problem is coming from.
« Reply #8 on: March 11, 2013, 05:14:22 PM »
Yes.
Just tried 053. no probs there
also 066 062
looks like only 057 shows this ( here )  ???
I keep 062  :)
Alex
