Hello Guest it is October 21, 2026, 06:48:16 PM
Author Topic: 2 Decimals DRO ?  (Read 18355 times)
2 Decimals DRO ?
« on: February 10, 2006, 03:33:05 PM »
Hello all,
On Mach3 V1.90.07 Can somebody tell me how to remove 2 decimals on all the DRO?
On a machine in decimal read 0.0001mm is not realistic!  I would like to read 0.01mm I tested %+.2f format string with Screen4  but the DRO do not function any more after the modification!
Another way ?
Thanks for your help  :)
Francis
« Last Edit: February 10, 2006, 05:33:28 PM by ftissera »
Re: 2 Decimals DRO ?
« Reply #1 on: February 10, 2006, 04:15:47 PM »
Try this :)
%+.2f
If you need to have NO +- you can use this %.2f
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 10, 2006, 04:48:27 PM »
Brian,
typo sorry, I just changed the "4" by "2" and left the other characters %+.4f becomes %+.2f it is all
With new screen in mach3 the display is +0.00 but the display is blocked to +0.00 when I jog  ???
After some tests when a DRO's modified with Screen4 it does not work anymore next even while giving it like as before
Thank you  :)
Francis
PS: I hope that you have not any neighbors, your dog is ferocious  ;D
« Last Edit: February 10, 2006, 05:08:40 PM by ftissera »
« Reply #3 on: February 11, 2006, 05:57:48 AM »
Brian,
today
1) reload my special 2 digits 1024ft.set in mach3.. don't work !
2) reload org 1024.set.. work fine !
3) reload another time my 1024ft.set and ... work fine   :-[
Don't understand but that work  ;D
Francis
« Reply #4 on: February 11, 2006, 06:03:17 AM »
It worked here when I tested it... I will keep an eye on it.
Thank you
Brian
www.machsupport.com
