Hello Guest it is November 22, 2026, 10:43:30 AM
Author Topic: mach 3 turn doubt  (Read 12260 times)
mach 3 turn doubt
« on: February 07, 2013, 04:44:27 AM »
hi everyone,
i am new to mach3 turn.
is there a option to bring the tool to the starting position(xz origin/program zero)
how does (zero world in x&z) work in program coordinate.
what is the difference between program coordinate & part coordinate home buttons.
if i am not clear with the question  please revert back . Urgent  need reply .....
regards
adhityan
INDIA
Re: mach 3 turn doubt
« Reply #1 on: February 07, 2013, 05:45:17 AM »
Have a look at Appendix "F" in the LazyTurn Manual which can be found in Member's Doc's.
Also there is a Manual for called Using Mach3Turn which provides more information.
« Reply #2 on: February 07, 2013, 07:18:47 AM »
hi rich,
i have already seen the "using Mach3Turn" doc.
the details related to this is given in Brief only.(ie info under machine setup family chapter)
« Reply #3 on: February 07, 2013, 03:50:44 PM »
Then have a read of the other manual as that gives a visual to the description.
« Reply #4 on: February 12, 2013, 03:42:51 AM »
hi rich
thanks for the info.
i am able to bring the tool to start position using g54 fixture offset.
why GO TO Z option is not available in turn as in mach3 mill as i can avoid typing g54 command in MDI
« Reply #5 on: February 12, 2013, 03:23:07 PM »
You can fairly easily make a lathe screenset similar in form and function of a mill screenset, in fact you can even use a mill screen if you wish as long as you rename it to .lset instead a .set.
I am not a fan of the standard lathe screenset and have never used it, I already had my own custom Mill screenset and I just adapted it for my lathes.
