Hello Guest it is November 13, 2026, 10:53:16 PM
Author Topic: MODBUS TCP in Mach3 R2.48  (Read 30990 times)
« on: January 30, 2013, 10:09:33 AM »
Hi!
Is it possible to use MODBUS TCP in Mach3 r2.48?
I tried to send some data to slave device in current version of Mach3 (R3.043) successfully.
But when I tried to use same configuration in r2.48 there was no data on slave device. Mach3 send only zeroes continuously. But in same time MODBUS TCP testing was OK.
I think that problem is connected with differences in BRAIN programs. In r3.043 I could select number of cfg to use, but in r2.48 I can only select the MODBUS address.
My clients use r2.48 and they don't want to upgrade to new version.
Best regards,
Alexey Kozletsov
