Hello Guest it is October 17, 2026, 03:35:20 PM
Author Topic: Five Axis  (Read 9318 times)
Offline kcib
  •  74 74
Five Axis
« on: January 16, 2013, 06:05:26 AM »
Hi to everyone
Just like a bit of clarification with homing, on vertical and gantry milling/routing machines the home position is normally bottom left hand corner now I have just converted my 3 axis gantry router to a full 5 axis and I have been told that all five axis machines home to the centre of the work table now I personally have not heard that before and was wondering if anyone out there could clarify where the home should be for a 5 axis router??
Alan
Re: Five Axis
« Reply #1 on: January 16, 2013, 10:09:14 AM »
Where a machine homes is strictly a matter of personal preference, because it really doesn't matter to the operation of the machine.  There is no "right" position for home, except, arguably, for the Z axis home should always be full up.  Most machines have X/Y/Z homes at one extreme of travel.
Re: Five Axis
« Reply #2 on: January 16, 2013, 10:27:15 AM »
Hi Alan,
  Perhaps you are referring to the Part Origin ?
If so, then in a 5 axis mill (trunion w/ rotary) might use the center of the level chuck as 0,0,0,0,0.
Would make sense to me, but that doesn't require much. ::)
Russ :)
Offline kcib
  •  74 74
Re: Five Axis
« Reply #3 on: January 16, 2013, 10:33:00 AM »
Hi Ray and Russ
for your responses much appreciated, I just wanted to make sure that I was not doing anything wrong by using what i class as the normal homing position, the machine is using a five axis head X,Y,Z,B,C,
Thanks again
Alan
