Hello Guest it is September 21, 2026, 06:34:48 PM
Author Topic: HELP HELP TO GET STARTED ON MOCK3 MILL  (Read 11237 times)
« on: January 15, 2013, 12:35:43 AM »
THANKS FOR LOOKING!!!!!!
I RECIENTLY PURCHASED MACH3.  I HAVE ONLY OPENED THE TRIAL VERSION AT THIS TIME.  WHEN I OPEN UP MACH3 MILL THE RESET BUTTON IS FLASHING AND A MESSAGE SAY THAT THE E-STOP IS ACTUATED.  I DO NOT HAVE THE SOFTWARE CONNECTED TO A MACHINE AND I HAVE NOT UNLOCKED THE DEMO VERSION WITH MY CODE.  I AM JUST TRYING TO PLAY AND LEARN THE PROGRAM.  SO FAR I CAN'T GET PAST THE E-STOP PROBLEM.
PLEASE HELP IF YOU CAN,  I WANT TO HAVE FUN WITH THE REST OF YOU GUYS
THANKS
HARRY
  •  9,372 9,372
Re: HELP HELP TO GET STARTED ON MOCK3 MILL
« Reply #1 on: January 15, 2013, 01:02:41 AM »
Hi Harry,
In Mach3 - Config / Ports & Pins / Input Signals - enable EStop and reverse the 'Active Low' setting. That should enable you to clear the condition.
« Reply #2 on: January 15, 2013, 05:27:09 AM »
Harry,
Tick the Emulated box also if not wired to a pin.
« Reply #3 on: January 15, 2013, 12:21:03 PM »
THANKS
I AM ON A ROLL NOW
HARRY
« Reply #4 on: January 15, 2013, 12:37:52 PM »
Great, now if we can just figure out how to get your keyboard fixed as the CAPS button seems to be stuck?  ;D
Welcome to the forum ;)
