Hello Guest it is November 26, 2026, 11:11:21 AM
Author Topic: Display WHOLE # Only in DRO  (Read 37244 times)
« on: December 06, 2012, 06:50:47 PM »
Hey,
  Is there a way to display the whole number value (integer?) only in a  %.0f  DRO without rounding up to the next digit ?
For example:
   Put 2 DRO's on screen w/the same OEM or User Code.
  Set #1 as 4 decimal place, and #2 as 0 decimal places.
If #1 shows 1.8, #2 will round up to 2
How can I capture just the whole number in #1.
Possible ?
Re: Display WHOLE # Only in DRO
« Reply #1 on: December 06, 2012, 07:45:50 PM »
Use a User DRO for the integer, and use the macropump to read the other DRO, trim off the decimals, and write to the User DRO.
Not terribly elegant, but it should work, no?
« Reply #2 on: December 06, 2012, 07:50:34 PM »
Ha ... sounds quite elegant !
How do I trim with the pump ?
Example ? ? ?
Thanks Ger
Russ
« Reply #3 on: December 06, 2012, 08:07:01 PM »
The interger function from what I see in Machscreen is broken. You get some weird number displayed.
IF you are populating a User dro then you could ROund down the number then send to the DRO .
OEMDROs most are control by the screen format.
« Reply #4 on: December 06, 2012, 08:13:25 PM »
Yep ... User DRO.  How can I round it dwn internally ?
Doing it manually now, gotta be a better way.
Both of you are encouraging.
Reading VB stuff now.....a lot like chineese ::)
« Reply #5 on: December 06, 2012, 08:20:44 PM »
I found this, but can't seem to relate it to "our" language.
http://www.vbforums.com/showthread.php?379158-How-to-Remove-Decimal-Part
« Reply #6 on: December 06, 2012, 08:29:38 PM »
... and this in the Mach book.
What would the proper syntax be ? ? ?
Wish I had a better grip on this.
« Reply #7 on: December 06, 2012, 08:33:15 PM »
Place something like this in the macropump macro.
DROInteger=CStr(GetOemDro(xx))
Length = Len(DROInteger)
For X = 1 To Length Step 1
lstring=Left(DROInteger,X)
If Right(lstring,1) = "." Then
NewLength = x-1
Exit For
End If
Next X
WholeNo=CInt(Left(DROInteger, NewLength))
SetOemDRO(xx)
« Reply #8 on: December 06, 2012, 08:48:44 PM »
Hi Ger,
 tried it, not working.
Changed OEM to User   ... no difference.
Here it is :
DROInteger=CStr(GetUserDro(1107))
NewLength = x-1
Exit For
End If
Next X
SetUserDRO(1106)
Getting  "ERROR on line: 24 - Argument not optional"
« Reply #9 on: December 06, 2012, 08:55:24 PM »
Oops.
Try SetUserDRO(xx, WholeNo)
