Hello Guest it is November 26, 2026, 11:11:21 AM
Author Topic: Display WHOLE # Only in DRO  (Read 37244 times)
Re: Display WHOLE # Only in DRO
« Reply #30 on: December 07, 2012, 04:34:33 PM »
Curiously, I started fresh, put this back in the pump and it works like a charm.
This went crazy later on (yesterday) but might now know why.
MaxStroke = GetUserDRO (1105)
CutLength = GetUserDRO (1100)
SawKerf = GetUserDRO (1104)
SetUserDRO (1107,MaxStroke / (CutLength + SawKerf))
SetUserDRO(1106,Fix(GetUserDRO (1107)))
Almost identical to your's TP, does it need the "If" and the Waits ?
NONE of these DRO's (1100,4 & 5) are moving, like an axis ... they are all fixed user entered values.
Task: See if you can get a SINGLE line script to do what the 2 lines above do.
This is what I thought I had working yesterday that crapped out on me. My "Simple" sample a few posts back.
Will be back later ........
Russ
« Reply #31 on: December 07, 2012, 04:37:38 PM »
Using R3.043.022
« Reply #32 on: December 07, 2012, 07:43:55 PM »
Without the check loop it continuously writes the DRO. With the loop IF the value has not changed it just exits saving the time slice of the write.
yes a single line your way or 2 lines my way(checkloop) should work just fine.
« Reply #33 on: December 07, 2012, 08:03:32 PM »
That is about as short as I can get it dependable.
SetUserDRO(1106,Fix (GetUserDro(1105)/(GetUserDro(1100) + GetUSerDro(1104))))
While Ismoving()
Wend
End
