Hello Guest it is November 26, 2026, 11:11:22 AM
Author Topic: Display WHOLE # Only in DRO  (Read 37244 times)
Re: Display WHOLE # Only in DRO
« Reply #10 on: December 06, 2012, 09:09:14 PM »
That works ... sort of.
Stepping through w/the editor is OK.
Won't run on its own.
There is more in the pump. Care to take a look ? Might need some waits in there. ?
Thanks Ger,
Russ
MaxStroke = GetUserDRO (1105)
CutLength = GetUserDRO (1100)
SawKerf = GetUserDRO (1104)
NumberOfCuts = GetUserDRO (1106)
Divider = GetUserDRO (1107)
'  This divides the available stroke by the Feed Increment
SetUserDRO (1107,MaxStroke / (CutLength + SawKerf) )
 '  This rounds it down to the nearestWhole number of Increments
DROInteger=CStr(GetUserDro(1107))
Length = Len(DROInteger)
For X = 1 To Length Step 1
lstring=Left(DROInteger,X)
If Right(lstring,1) = "." Then
NewLength = x-1
Exit For
End If
Next X
WholeNo=CInt(Left(DROInteger, NewLength))
SetUserDRO(1106,WholeNo)
« Reply #11 on: December 06, 2012, 09:14:21 PM »
Try
DROInteger=CStr(MaxStroke / (CutLength + SawKerf))
That way you're not trying to read the DRO right after you right to it.
I don't know if you can wait in a macropump, because you don't have much time.
« Reply #12 on: December 06, 2012, 09:24:17 PM »
not quite right yet Ger.
Last suggestion did not work at all, even commented out the previous code and stepping through.
Back as it was, steps through OK but won't run auto.
Russ
« Reply #13 on: December 06, 2012, 09:38:56 PM »
Try   SetUserDro(##, Fix(GetOemDro(##) )    ' Where the ## are the DRO numbers
Just a thought, (;-) TP
« Reply #14 on: December 06, 2012, 09:41:27 PM »
I was playing with Fix in the editor and it kept giving me bad syntax errors, and I couldn't figure it out.
« Reply #15 on: December 06, 2012, 09:42:20 PM »
IF you are going to use the macro pump you need to loop out IF the 2 dros are the same number to prevent all the overwriting going on THAT eats up processor time.
« Reply #16 on: December 06, 2012, 09:48:26 PM »
Tried TP's w/ Fix and Int ...neither worked.
Tried these plus Ger's in a button. So as to not conflict with the pump
Ger's worked 1 time, the returned a 0
« Reply #17 on: December 06, 2012, 10:14:06 PM »
Here's  what I HAVE running in the macropump here.
 Works fine tracks the Xdro exactly to the whole number. The IF statement checks to see IF the 2 values are the same if they are then it ends otherwise it writes thenew value to the UserDRO(1555).
If Fix(GetDro(0)) = GetUserDro(1555) Then
End
End If
SetUserDro(1555, Fix(GetDro(0)))
While Ismoving()
Wend
End
« Reply #18 on: December 06, 2012, 10:34:40 PM »
That works fine in a Button,( after changing all to UserDRO's) but it wont run in my pump along with the other line.
Might just have to leave it in a button ? ? ? Just 1 extra step I was trying to avoid.
Thanks TP
MPmp
NumberOfCuts = GetUserDRO (1106) 'Interger, actual cut increments
Divider      = GetUserDRO (1107) 'raw decimal # xx.*********x
'TP's Goody....................
If Fix(GetUserDro(1107)) = GetUserDro(1106) Then
End
End If
SetUserDro(1106, Fix(GetUserDro(1107)))
While Ismoving()
Wend
End
« Reply #19 on: December 06, 2012, 10:54:51 PM »
Thanks Guys for the points to the right direction.
Can it possibly be this simple ? ??
This one line does it all ... perfectly , so far.
SetUserDRO(1106,Fix(GetMaxStroke)/(CutLength+SawKerf))
Right in the pump, no button needed.
Fingers crossed.
Thanks again !
Russ
« Last Edit: December 06, 2012, 10:57:36 PM by Overloaded »
