Hello Guest it is November 22, 2026, 03:26:52 PM
Author Topic: Sanyo Denki BL Super servos  (Read 56962 times)
« on: January 26, 2007, 09:01:51 AM »
Hi
I just got myself 4 Sanyo Denki BL Super servos for free, inkl drives.
I just briefly looked trough the manuals , and it looks like they can be used for positioning control by negative command pulses and positive, they also have encoders for feedback.
Does anyone know if this equipment is possible to run under Mach 3?
I am planning to substitude my steppers for these servos.
They used to be controlled by an Omron PLC.
Best Reg
Cory
Re: Sanyo Denki BL Super servos
« Reply #1 on: January 26, 2007, 11:28:40 AM »
If the drives have position control, they should work. There will be several parameters that have to be set.
Example:
Position control
Signal type
Pulses per motor revolution
They will run circles around your stepper setup!
Darek
« Reply #2 on: January 26, 2007, 01:09:23 PM »
Thats good to hear.
The motors should be more than powerful enogh,they are 720 w 220v single fase ac servos with a max continious torque of 30 kg-cm and
constant torque of 8,2 kg-cm/arms.  Dont know the specs in Nm.
The spin at max of 3000 rpm, and the encoder has 2000 step/rev.
Anyone has any idea how to connect this?
Do I run the printer port cable that i use for my stepper BOB onto the amplifiers command pulse terminals?
If it helps,I could porpably scan the connectoin diagram frrom the manual, and post it here.
Thanx in advance
Cory
« Last Edit: January 26, 2007, 01:11:44 PM by corydoras »
« Reply #3 on: February 05, 2007, 05:29:12 PM »
hi corydoras
sorry i cant answer your question but i have some of these sanyo denki drives and i am desperate for the connection diagram,  if you would be willing to email to me, i would be a really happy chappy ;).
regards sneakym8
« Reply #4 on: February 05, 2007, 08:17:09 PM »
So the drive uses one pin to step the motor foward and back based on + or- input?
« Reply #5 on: February 05, 2007, 11:28:51 PM »
Sneaky8, ill see if I can get my hands on a scanner, and e-mail them to you.
Dennis:The mototr can be used for position control or velocity control, based on the status of one of the input pins.
It hs 2 input pins for negative command pulse and 2 for positive comand pulse, but the manual says that it can be controlled either with  either 2 puls-trains, one for each diration or with one for pule and one for direction.
I am not sure about the excact conection, but maby this becomes clear when I get my hands on a scanner.
I have an old Hp scanner but there are no drivers available for Win xp
Cory
« Last Edit: February 05, 2007, 11:34:50 PM by corydoras »
« Reply #6 on: February 06, 2007, 04:51:43 AM »
cheers cory
i have a mahine with these drives on it, and we have a fault on it , so its never run for some time now,hopefully it will aid me to find the fault.
thanks in anticipation ...
regards sneakym8
« Reply #7 on: February 06, 2007, 11:19:59 AM »
Got it!  So these are regular drives that take CW +/- and CCW +/- .  The drives that I have can run both modes CW/CCW and step/dir so I didn't look in to making a cuircuit for the CW/CCW inputs.  Maybe your drives can be configured to run step/dir if not, then you need one of these or similar chips here: http://en.wikipedia.org/wiki/List_of_4000_series_integrated_circuits.  You just need a IC to switch pins based on the direction pin output from your BOB.
« Last Edit: February 06, 2007, 01:40:52 PM by DennisCNC »
« Reply #8 on: February 13, 2007, 09:23:04 AM »
Finally!!
I got the time and oportunity to scan the connection diagram, so hopefully someone could take a look at this and give me somhints on hoe to connect this to my paralellport or my BOB.
Sneaky; you´ve got mail
Bet reg
Cory
« Reply #9 on: February 13, 2007, 10:40:47 AM »
They do not show the internals. This is from the PZ series documentation. I would image yours is the same. It has a differential line receiver input. If you have to run long signal wires the differential line driver is the way to go other wise use the open collector option shown.
Darek
