Hello Guest it is November 12, 2026, 02:25:54 AM
Author Topic: Using a spindle sensor for Mach and VFD  (Read 19624 times)
Offline derek
  •  200 200
« on: November 18, 2012, 09:36:55 AM »
Hi
I have a  spindle sensor setup using a QRB 1134  optical sensor. I'm installing a Delta VFD-M for my ATC. It has an option for indexing the spindle.   It has programmable digital inputs.
Is there a way to share the signal from the sensor between the VFD and Mach.
Derek
Re: Using a spindle sensor for Mach and VFD
« Reply #1 on: November 18, 2012, 10:18:22 AM »
Have a look and see if there is an output in the VFD for the revs, you may be able to configure an output to puit out a pulse every rev.
Offline derek
  •  200 200
« Reply #2 on: November 18, 2012, 10:30:59 AM »
Actually I'm trying to go the other way. I need the optical sensor to signal the VFD so it can index.
It has a simple indexing function. The vfd shuts down then turns slowly till the sensor triggers. It pulls an input on the VFD low. It then turns to a programmed angle. I'm curious if I can just run the signal wire to the VFD and share it between the two
Derek
« Reply #3 on: November 18, 2012, 10:37:21 AM »
Derek you run the risk of different voltages of the signals. Might want to consider a very small relay or electronic switch to separate the 2 signals.
Just a thought, (;-) TP
« Reply #4 on: November 18, 2012, 10:41:54 AM »
What I would try is using a Brain. as the index signal to the VFD will be at low revs then it might be ok.
Have the index signal go to Mach as normal then have a brain switch an output using the Index as a trigger, have the oput[put going to the VFD. Might not be good enough but not much hassle to try.
Offline derek
  •  200 200
« Reply #5 on: November 18, 2012, 11:04:10 AM »
I have a pokeys to run the ATC if that would make things easier
« Reply #6 on: November 18, 2012, 11:11:13 AM »
I would have the index going into Mach via whatever you are using as the controller, ie parallel port or smoothstepper or.........
Offline derek
  •  200 200
« Reply #7 on: November 18, 2012, 11:47:31 AM »
I'm using a parallel port. So if I run a wire from the parallel port to the input pin on the VFD are there any issues I should be aware of?
I'm worried my ignorance could be costly this time!
Derek
« Reply #8 on: November 18, 2012, 12:07:07 PM »
I F you use the Brian approach consider an AND function with a led. That way you can turn the function on and off when needed. It keeps the brain from pulsing the output all the time.
Hood, Good call on using a brain to reroute the signal.
I would NOT wire anything direct to the LPT port I would run a GOOD BOB in between to isolate signals .  IF you mistaking input 24v into your PC/BOB it could toast it .
« Reply #9 on: November 18, 2012, 12:17:52 PM »
I would echo that, isolation is always a wise move.
