Mach Discussion => General Mach Discussion => Topic started by: derek on November 18, 2012, 10:36:55 AM
Title: Using a spindle sensor for Mach and VFD
Post by: derek on November 18, 2012, 10:36:55 AM
Hi
I have a  spindle sensor setup using a QRB 1134  optical sensor. I'm installing a Delta VFD-M for my ATC. It has an option for indexing the spindle.   It has programmable digital inputs.
Is there a way to share the signal from the sensor between the VFD and Mach.
Derek
Title: Re: Using a spindle sensor for Mach and VFD
Post by: Hood on November 18, 2012, 11:18:22 AM
Have a look and see if there is an output in the VFD for the revs, you may be able to configure an output to puit out a pulse every rev.
Post by: derek on November 18, 2012, 11:30:59 AM
Actually I'm trying to go the other way. I need the optical sensor to signal the VFD so it can index.
It has a simple indexing function. The vfd shuts down then turns slowly till the sensor triggers. It pulls an input on the VFD low. It then turns to a programmed angle. I'm curious if I can just run the signal wire to the VFD and share it between the two
Derek
Post by: BR549 on November 18, 2012, 11:37:21 AM
Derek you run the risk of different voltages of the signals. Might want to consider a very small relay or electronic switch to separate the 2 signals.
Just a thought, (;-) TP
Post by: Hood on November 18, 2012, 11:41:54 AM
What I would try is using a Brain. as the index signal to the VFD will be at low revs then it might be ok.
Have the index signal go to Mach as normal then have a brain switch an output using the Index as a trigger, have the oput[put going to the VFD. Might not be good enough but not much hassle to try.
Post by: derek on November 18, 2012, 12:04:10 PM
I have a pokeys to run the ATC if that would make things easier
Post by: Hood on November 18, 2012, 12:11:13 PM
I would have the index going into Mach via whatever you are using as the controller, ie parallel port or smoothstepper or.........
Post by: derek on November 18, 2012, 12:47:31 PM
I'm using a parallel port. So if I run a wire from the parallel port to the input pin on the VFD are there any issues I should be aware of?
I'm worried my ignorance could be costly this time!
Derek
Post by: BR549 on November 18, 2012, 01:07:07 PM
I F you use the Brian approach consider an AND function with a led. That way you can turn the function on and off when needed. It keeps the brain from pulsing the output all the time.
Hood, Good call on using a brain to reroute the signal.
I would NOT wire anything direct to the LPT port I would run a GOOD BOB in between to isolate signals .  IF you mistaking input 24v into your PC/BOB it could toast it .
Post by: Hood on November 18, 2012, 01:17:52 PM
I would echo that, isolation is always a wise move.
Post by: derek on November 18, 2012, 02:56:29 PM
Thanks for the help.
This gives me some food for thought.
Derek
Post by: BR549 on November 18, 2012, 10:02:37 PM
Derek this would work to safely interface your rutex MB output to teh input of the VFD.
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=24&products_id=273
