Hello
Guest
it is
November 13, 2026, 03:11:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach 3 wants to start much lower than ZERO, tool offset IS turned off
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Mach 3 wants to start much lower than ZERO, tool offset IS turned off (Read 23919 times)
Rotax91
16
on:
October 28, 2012, 06:33:03 PM »
Hey guys,
Can someone please enlighten me on what I might be doing wrong. I'm using mach 3 with Vectric aspire. It's been a couple months since my last cut and suddenly it has a mind of it's own. I touch off the surface of the material with Z and Zero it out. I'm not using any tool offsets and I did verify that it is turned off. When I start the run, Z is plunges down MUCH further than it should be. It should be going down to my Safe Z (0.2) and going on into the program from there.
Anyone got any ideas?
Thanks.
angel tech
499
Re: Mach 3 wants to start much lower than ZERO, tool offset IS turned off
Reply #1 on:
October 28, 2012, 06:40:59 PM »
does vectric call a toolchange at the start of the code, and set an offset. ?
Rotax91
16
Reply #2 on:
October 28, 2012, 06:52:49 PM »
Hi. Thanks for trying to help. I verified an it's using Tool #1. Actually everything I run is tool 1. If there is multiple tool uses (end mill, vbit, ballnose), in my job, I break them up into multiple jobs. 1 job for each tool.
angel tech
499
Reply #3 on:
October 28, 2012, 06:58:08 PM »
is the z axis going the right way, + up and - down
can you put the first dozen or so lines of code up. When Hood gets on here he'll look at your xml, so it might be worth posting that.
Last Edit: October 28, 2012, 06:59:58 PM by angel tech
Rotax91
16
Reply #4 on:
October 28, 2012, 07:41:23 PM »
Hi, Yes absolutely. I will post a few lines of the gcode and the g540.xml file. Yes, the Z does go in the right direction. Just goes too far.
Thanks.
ger21
6,295
Reply #5 on:
October 28, 2012, 07:56:07 PM »
Do you have a tool length in the tooltable? You're code uses a G43 length offset, so that could be doing it.
Rotax91
16
Reply #6 on:
October 28, 2012, 08:06:29 PM »
HI Ger, Thanks for attempting to help out. I'm out in the garage look at the screen right now. Tool 1 & ALL the rest of the tools are ZEROES across the board. How can I turn that G43 off?
EDIT: Are you saying the gcode has the g43 or the xml?
Last Edit: October 28, 2012, 08:11:36 PM by Rotax91
Rotax91
16
Reply #7 on:
October 28, 2012, 08:43:16 PM »
I see this line: N140G00G43Z0.8000H1
I have no idea what is telling it to put in a G43 though.
Rotax91
16
Reply #8 on:
October 28, 2012, 09:30:28 PM »
I just edited the vectric mach 3 .PP post processor and took the G43 out of the header.
Gonna go try it now.
Does anyone have a newer vectric .pp file. Mine is dated 12/15/09
Rotax91
16
Reply #9 on:
October 28, 2012, 09:57:28 PM »
Back in business!!!! Taking that G43 out of the vectric mach3 post processor header did it. I actually edited the .pp file to prevent G43 from getting put in ever again.
Print
Pages:
1
2
Go Up
« previous
next »
