Hello
Guest
it is
November 13, 2026, 09:36:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Radius Comp
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Radius Comp (Read 15653 times)
rcrabb
146
Radius Comp
on:
January 23, 2007, 08:29:48 AM »
My radius comp LED always on. I can't seem to get it turned off. I checked the XML and radius comp off is 1. I also made sure the LED on the screenset is asigned the correct OEMLED value. Any ideas?
Logged
Ryan
Chaoticone
5,624
Precision Chaos
Re: Radius Comp
Reply #1 on:
January 23, 2007, 08:41:46 AM »
Hey Ryan,
Is it doing this while you have code loaded? Is there a G41 or G42 in your code?
Logged
If you could see the things I have in my head, you would be laughing too.
rcrabb
146
Re: Radius Comp
Reply #2 on:
January 23, 2007, 08:45:48 AM »
No code loaded. I even did A G40.
Logged
Ryan
Chaoticone
5,624
Precision Chaos
Re: Radius Comp
Reply #3 on:
January 23, 2007, 08:53:41 AM »
In general config, ports and pins, mill options, is advanced compensation on in there?
Logged
rcrabb
146
Re: Radius Comp
Reply #4 on:
January 23, 2007, 09:59:43 AM »
I turned it off and the radius comp LED is still on. Even resarted mach and did a G40.
Logged
Ryan
Chaoticone
5,624
Precision Chaos
Re: Radius Comp
Reply #5 on:
January 23, 2007, 10:10:46 AM »
What version of Mach are you running Ryan? I will do some test tonight.
Logged
rcrabb
146
Re: Radius Comp
Reply #6 on:
January 23, 2007, 12:47:01 PM »
2.0.038
Logged
Ryan
Print
Pages:
1
Go Up
« previous
next »
