Hello
Guest
it is
November 13, 2026, 11:56:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
auto calculator decimal point not working
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: auto calculator decimal point not working (Read 14434 times)
tantan
130
on:
October 12, 2012, 12:45:40 PM »
hi,
i use the auto calculator tool with a toch screen to enter values in the dro's. but the decimal point is not working.
tantan
Overloaded
4,923
Re: auto calculator decimal point not working
Reply #1 on:
October 12, 2012, 12:48:20 PM »
When using the calculator, always enter a "0" (or some digit) before the decimal point.
Like this .... 0.4375
Russ
tantan
130
Reply #2 on:
October 12, 2012, 12:58:52 PM »
hi,
tnx for your reply. i always do that but even 12.56 dus not work. the decimal point is not working at all.
tantan
Overloaded
4,923
Reply #3 on:
October 12, 2012, 01:06:23 PM »
Might be associated with your touch screen set-up.
Wish I could help there but have no experience with them.
Russ
tantan
130
Reply #4 on:
October 12, 2012, 01:13:52 PM »
hi russ,
it has nothing to do with touchscreen drivers. if you would be so kind just select auto calculator in the operator menu. now you can fill in a value in an dro with your mouse. if you try for example 34.89 you will find that 34. will work but the 89 you cannot fill in.
tnx
tantan
Overloaded
4,923
Reply #5 on:
October 12, 2012, 01:19:52 PM »
I did try it before first posting and it works fine here.
Are you using the standard Mach screen ?
If not, the dro might not be set to accept decimal entries. (%+.2f)
tantan
130
Reply #6 on:
October 12, 2012, 01:29:17 PM »
hi,
i solved it. it has to do with country settings in windows. i configured dutch (netherlands). after i configured English (US) it works!!
thanks!
tantan
Overloaded
4,923
Reply #7 on:
October 12, 2012, 01:36:19 PM »
Bravo !
I'll try to remember this one for future reference.
Thank YOU !
Russ
Carnoustie, Scotland
Reply #8 on:
October 12, 2012, 03:23:15 PM »
Yes, there was a French guy had the same issue, thought at first it may be because he was using a laptop but ended up it was the language option he had set. He set the keyboard to UK and it worked fine.
Print
Pages:
1
Go Up
« previous
next »
